HID debate
Old Feb 6, 2012 | 08:32 PM
ComputerCowboy's Avatar
ComputerCowboy
Originally Posted by High Intentions
I had 4300's in my 2000 factory style headlight and is one of my fav's. When I went tp the 05 headlight had to get the newer style bulb. The set up I went with only went down to 5000. The 4300 has a very slight hint of yellow to it. Some outfits say 4300 is pure white others say 6000 in pure white?? I have seen some ricers around here with blue almost purple.. Don't know how they are able to see with those?
6000K through 6500K is pure white. I have done a lot of work with digital front projection systems, a hobby of mine, and all of the bulbs for the commercial and home brew units are in that range. You need pure white for any sort of quality projection system,front or rear, digital or analog. If you didn't have a 6000K color temperature skin tones and other colors would be messed up.
As far as headlights go it is just a matter of preference. I like cool almost to blue, higher color temp, like 7000K.
Old Feb 6, 2012 | 08:45 PM
MRyanF's Avatar
MRyanF
Most OEM's are 6000 or up now.
Old Feb 6, 2012 | 09:05 PM
william_04_x's Avatar
william_04_x
Wattage also affects color. A 55wt 6000K lamp will look whiter than a 35wt 6000K. Here's a pic to show the difference. The H/L's are 55wt and aux lights are 35 wt. All are 6000K lamps.
For my X, I've had 4300K in both the fogs(35wt) and H/L's(55wt high/low). They will have a slight yellow tint, which I don't like. I switched to 5000K lamps, with the original ballasts, and the light is white(what I want). 6000K will have a slight blue tint. The amount of light cast from anything between 4300K-6000K is so close it's almost imperceptible. When you go above/below that range, the amount of light starts to drop off pretty quickly.
Old Feb 6, 2012 | 09:28 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
you can see my opinion on the subject! LOL
Old Feb 6, 2012 | 09:48 PM
lovestrucks's Avatar
lovestrucks
I got 55w 4300k on mine...pics in my garage
Old Feb 7, 2012 | 08:20 AM
Snowseeker's Avatar
Snowseeker
I see pics of the bulbs, can we get pics of the lights on at night to see color and stuff please.
Old Feb 7, 2012 | 11:28 AM
LivingLarge's Avatar
LivingLarge
HID Debate, oops thought this thread was about-
HIDeous Politicians Debating.
Old Feb 7, 2012 | 01:12 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
I love mine, I have the 14,000k. Just kidding, I have 5000k and I do like them alot, no blue tint and very bright. I have hi/lo set up and don't think I will ever need the Hi beams. I had 5000k in my Land Rover and when I got my X I really missed the light output.
Old Feb 7, 2012 | 06:31 PM
aortizexcursion's Avatar
aortizexcursion
Originally Posted by Snowseeker
Personally I don't like the projector perfect cut off. Load one more person in the back seat and that cutoff is now above the mirrors of the car ahead of you blinding them with 100% of the HID output. Same with going over bumps and stuff, I hate when a car behind me is bouncing along constantly "flashing me". I always think someone is flashing their lights at me because there is a problem or something.
Explain to me how the same thing doesn't happen to vehicles without projectors. I have yet to experience a vehicle with properly setup projectors blind me; I have however experienced a vehicle without projectors and with regular halogens blind me because they are raked back due to weight. The affect is even worse when these non-projector equipped vehicles with weight have HIDs thrown in. Besides, most of us Excursion owners have beefed up rear suspensions that resist rear sag. The bottom-line is that our stock headlight housings were not designed for HIDs, am I right? That of course doesn't mean to not run HIDs in stock housings but regardless, our housing were not made for the different light output distribution characteristics of HIDs.
Read this if you are open to learning something:
Daniel Stern Lighting Consultancy and Supply
Same in reverse for the driver of the car. Can't see anything above the cutoff line so if you have your lights aimed even a little to low you can't see whats down the road ahead of you. I have ridden in these cars and noticed you can't even see pedestrians on the road ahead of you because they aren't lit up, only their shoes are lit up and if they aren't reflective you would never know the person is there. The same goes for deer, bears, moose, etc. Also opposite deal with going over bumps while being in the car with projectors, going over bumps you think to yourself "I can see, I can't see, I can see, I can't see."
I'd rather blind a few people with little cars and see everything rather than blind everyone on bumpy roads or if I have a person in the back seat and NOT see that kid riding his bike on the side of the road.
As for discussion on beam patterns, read this:
The HID FAQ Thread - Read before posting your questions - Page 12 - NASIOC
The post of significance is post #283
Old Feb 7, 2012 | 08:55 PM
Snowseeker's Avatar
Snowseeker
Yes I agree lots if not most halogen cars converted to HID have bad blinding spots, some vehicles shouldn't have them at all. However some housings do a good job of controlling the light and I believe the 05+ superduty housings do a pretty good job. I never had a problem being flashed by any of the HID converted SD's I see on the road and I do allot of driving. Now the chevy trucks on the other hand just plain suck even with the stock halogens! They are always blinding.
Old Feb 7, 2012 | 08:59 PM
archtaan's Avatar
archtaan
Well I ordered Recon 2008-2010 Projector headlights for the EX. I still have my old 9007's so I think I will do a test with halogens in the projector lenses and then the same HID kit in the projector lens just for giggles. Why not huh?
Old Feb 7, 2012 | 09:02 PM
aortizexcursion
For the sake of technicalities, here is a diagram showing the difference between HIDs and Halogen bulbs in terms of light output characteristics and why optics are important with HIDs.
Old Feb 7, 2012 | 09:03 PM
  #28
aortizexcursion
That would be a nice comparison.
Old Feb 7, 2012 | 09:58 PM
  #29
tims01's Avatar
tims01
i love mine all 4 of them
Old Feb 8, 2012 | 04:17 AM
  #30
Fuha's Avatar
Fuha
without knowing much about HID i appericate all the links yall have givin out. However, with as much as some of this goes over my head I am grasping some. As a person that is a Commerical driver that covers about 110k miles a year and 95% of that being at night I do see lots of headlights and know were everyone that has posted on both sides of this come from. I belive I will be putting the xtreme power halogens in my commerical vehicle. Have decieded about the X but it sees 95% of daytime driving.
