some gauge cluster questions
Old Feb 5, 2012 | 09:09 PM
kyle1979ford's Avatar
kyle1979ford
i pulled a cluster out of a truck that was going to the crusher (rust everywhere) and i noticed that it has some differences than the cluster in my 78. this one goes to 100mph has some chrome accents and its all black. sorry if this is a dumb thread im just curious what things changed between trim packages, years, etc..
it looks real nice, im thinkin of putting it in my 78. how do i correct the speedometer so it reads correctly?
how do i hook up the speedometer cable? when i took it out i broke the white plastic piece that holds the cluster to the cable. dont worry the cluster is good, just wanna know how to properly remove the speedo cable
and last question, what do you guys do about the odometer?
Old Feb 5, 2012 | 11:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That cluster is out of a pre-77 model. They went to the 85 mph speedo in mid 77. You don't need to do anything different to use it. The calibration was in the speedometer not the drive.
To properly remove the cable from the speedo, on the plastic collar that hooks the cable to the unit there's a tab, squeeze this together and you can then pull the cable from the unit.
As for the odometer. They can be reset but it's a pita and legally questionable.
Old Feb 6, 2012 | 09:15 PM
nutinbutford's Avatar
nutinbutford
is your original equipped with guages or lights? what about the donor dash?
it may not be an issue, others may know if you'll have an issue with the guages/lights working properly if your truck originally had one or other.
Old Feb 6, 2012 | 09:18 PM
fmc400's Avatar
fmc400
MSEE
Agreed, both trucks had to have gauges or lights if you're wanting to swap the entire cluster and not just the speedometer. There are also some other year-to-year differences based on a seat belt warning light, economy light, etc. They are not universally interchangeable.
Another difference in speedometers is the location of the high-beam jewel.
Old Feb 6, 2012 | 09:30 PM
critterf1's Avatar
critterf1
Subtle changes occurred from year to year and model to model.
Old Feb 7, 2012 | 05:48 AM
dowurk74's Avatar
dowurk74
to join in.... like kyle i pulled two different clusters out of older models trucks... 1. does it matter what printed circuit i used for my 74 and come to find out that the pin clip( i wanna say the 18 could be wrong) was broken prior to me removing it... will this affect my cluster not working other than the speedo? oh and all clusters match meaning all have gauges not idiot lights.
Old Feb 7, 2012 | 06:25 AM
OldStyle's Avatar
OldStyle
Rusty Roller
dowurk74,
Good advice; as usual...
Is the broken board on your original? Broken at the plug or burnt circuit?
There is a part number printed on the circuit board. If they match you can change over the board. If your original is good use it.
Old Feb 7, 2012 | 12:09 PM
dowurk74's Avatar
dowurk74
Originally Posted by OldStyle
dowurk74,
the clip where it snaps into the back of the cluster is broken.. shldve been a wee bit clearer. i guess i want to say the actual harness clip. will take affect the performance?
Old Feb 7, 2012 | 04:34 PM
kyle1979ford
i want to swap the whole cluster. its out of a 77 or older 2wd truck. i thought i could just unplug and switch the two
Old Feb 7, 2012 | 06:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Printed Circuit Boards: 1973/79 F100/350 / 1975/91 Econoline / 1978/79 Bronco
There is a ID engineering number printed on the circuit board.
If they match, you can change over the board.
D3TZ-10K843-A .. Printed Circuit Board / Use with Oil/Amp Gauges / Marked w/ID engineering number: D3TF-10C956-AA
Applications: 1973/74 F100/350.
D3TZ-10K843-B .. Printed Circuit Board / Use with Oil/Amp Warning Lights / Marked: D3TF-10C956-CA
Applications: 1973/75 F100/350 / 1975 Econoline.
D5TZ-10K843-A .. Printed Circuit Board / Use with Oil/Amp Gauges / Marked D5TF-10C956-AA
Applications: 1975 F100/350 before serial number W40,001.
D5TZ-10K843-C .. Printed Circuit Board / Use with Oil/Amp Gauges / Marked: D5TF-10C956-CA
Applications: 1975 F100/350 from serial number W40,001 / 1975 Econoline.
D6TZ-10K843-B .. Printed Circuit Board / Use with Oil/Amp Gauges / Marked: D6TF-10C956-BA
Applications: 1976/79 F100/350 / 1976/91 Econoline / 1978/79 Bronco.
D6TZ-10K843-C .. Printed Circuit Board / Use with Oil/Amp Warning Lights / Marked: D6TF-10956-CA
Applications: 1976/78 F100/350, Bronco & Econoline.
D9TZ-10K843-A .. Printed Circuit Board / Use with Oil/Amp Warning Lights / Marked: D9TF-10C956-AA
Applications: 1979 F100/350 & Bronco / 1979/86 Econoline.
BE AWARE: 1975/79 F100/350 / 1975/80 Econoline / 1978/79 Bronco came with instrument cluster backs made from a composition material that can TURN TO DUST before your very eyes!
BlueOx460
Aug 4, 2016 05:07 PM
hermancm
13
Jun 19, 2012 08:02 AM
three on the tree
Oct 25, 2010 02:58 PM
jason433
May 2, 2007 11:09 AM
mharper
Bronco II
Feb 14, 2007 12:51 PM
