Hub question
Old Feb 3, 2012 | 08:35 PM
C350CREW's Avatar
C350CREW
Hub question
OK, I have searched for an answer but still cant be positive. Took my hub off to replace the rotor and I found only one lock nut with a c shaped clip that stops the nut from backing off. I have auto hubs on a F350 4wd. All the info I found in the search's, talk about 2 nuts with a lock ring in between. Am I missing parts or is this correct for what I have? Pretty sure it is a D60. Any help will be greatly appreciated.
Old Feb 3, 2012 | 08:52 PM
427 fordman's Avatar
427 fordman
That is correct. At least it is on my 50 with auto hubs, I'm thinking they are the same. That clip has a "tang" on it that slips into the nut right?
Old Feb 3, 2012 | 09:02 PM
C350CREW's Avatar
C350CREW
Yup, that is what keeps the nut from backing off. So do I have a 50 or 60? How do you tell the diff?
Old Feb 3, 2012 | 09:06 PM
427 fordman
60 is a solid axle. You have a 60 in the 350. 250's came with 50's which are not a solid axle.
Old Feb 3, 2012 | 09:12 PM
BlueMule's Avatar
BlueMule
The OEM Ford hubs were built by Warn. Figure #2 in the following link shows the auto hubs that were on the D60
http://warn.iwebcat.com/imgVD/WAR/32722A2-pn32721.pdf
Old Feb 3, 2012 | 09:13 PM
C350CREW's Avatar
C350CREW
Got it, kinda thought the 50 was not a solid but wanted to make sure. This is the newest year ford I have ever owned. All my others were pre 79. Sometimes I really miss them years, could fix anything without even thinking. Now I am starting over on the learning curve, but I sure love them diesels, so guess I will keep learning and askin questions. Thanks a bunch, gonna pack some bearings and start puttin it back together. Who needs sleep anyway, right?
r59
26
Sep 21, 2024 09:48 PM
wannabe7.3
Feb 7, 2015 10:09 PM
Bertha1
15
Dec 4, 2007 01:10 PM
Ilikebigtrucks
Oct 31, 2006 11:36 PM
rcassara
1978 - 1996 Big Bronco
Oct 11, 2004 09:26 AM
