front hub missing hex nut on axle
Old Feb 7, 2015 | 02:17 PM
wannabe7.3's Avatar
wannabe7.3
working on a buddies 99 f250 and his hubs weren't unlocking. took the riverside apart and theres no hex nut on the axle! there is one on the passenger side. is there suppose to be one on the Driverside?
Old Feb 7, 2015 | 05:01 PM
David7.3's Avatar
David7.3
There should be no hub nut on any side, there sealed bearings and the axle shaft should be held in with a snap ring. I dont know what is going on there someone played around with it.
Old Feb 7, 2015 | 07:09 PM
mueckster's Avatar
mueckster
Are you referring to the plastic hex shaped thrust washer? You should have them on both sides.
AllaboutMPG's Avatar
AllaboutMPG
I think he's talking about the plastic shim nut and yes both sides should be the same. Parts are inexpensive.
You are talking about OEM auto locking hubs, correct?
Old Feb 7, 2015 | 07:23 PM
AllaboutMPG
part way down this "how to" is a picture of the order they are installed
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
washer kit
http://www.drivetrainamerica.com/p-6...asher-kit.aspx
Old Feb 7, 2015 | 08:50 PM
Firefighter 1406's Avatar
Firefighter 1406
Can he that washer through www.dieselorings.com as well.
Old Feb 7, 2015 | 10:09 PM
mueckster's Avatar
mueckster
Originally Posted by Firefighter 1406
Can he that washer through DieselOrings as well.
Yes, he can! Front Hub Thrust Washers - 1999-2004 Ford 7.3 Diesel Axle
shawngordonjr
Nov 26, 2017 07:14 PM
chiefsfootball
Jan 20, 2015 02:18 PM
RabidJade
Jan 18, 2014 05:38 AM
ltsmitty
Dec 29, 2006 11:22 PM
rcassara
1978 - 1996 Big Bronco
Oct 11, 2004 09:26 AM
