Plastic vacuum lines broken
Old Feb 3, 2012 | 02:10 PM
Eliyahu's Avatar
Eliyahu
The plastic vacuum lines (whatever happened to the rubber ones we used to use) on my 96 F250 on the passenger side of the engine have broken. They're the ones going to the vacuum reserve tank. It looks like they run under the plenum and back into who-knows-where. How big a task will it be to replace this thing and is there a way to just fix the lines instead of replacing? 5.8L engine, if that matters.
Old Feb 3, 2012 | 02:49 PM
jas88's Avatar
jas88
I usually just patch them with rubber hoses, or replace altogether with rubber.
Old Feb 3, 2012 | 04:39 PM
hivoltj's Avatar
hivoltj
^^^ What he said. I've found the stiffer, clear vinyl tubing to be a tighter fit. You can find it at the hardware store, and a little glue makes sure the joints stay together.
Old Feb 4, 2012 | 02:40 PM
Eliyahu's Avatar
Eliyahu
Seems to have worked.
I patched the lines with clear vinyl tubing this morning. I'm going to wait for the silicone goop to cure (24 hours recommended) before I fire it up, but I'm hoping this will eliminate the omnipresent "check engine" light on the dash and that the gas mileage will improve now. With 176,000 miles on the truck, I plan to replace the fuel filter as well, but one thing at a time.
Old Feb 4, 2012 | 07:35 PM
DPorter's Avatar
DPorter
heat shrink tube with sealant works too if in the middle and a clean tight break.
jim0517
Oct 8, 2011 07:21 PM
GMan1
Jul 18, 2009 07:42 PM
tatetodd
Feb 5, 2007 12:45 PM
Coneynew
Jan 2, 2007 10:44 AM
Matt Wilson
13
Apr 5, 2005 01:27 PM
