Sponsored by: Real Truck
Need to replace vacuum lines
Old Sep 27, 2011 | 03:03 PM
jim0517's Avatar
jim0517
I've got a vacuum leak and started looking at the lines. It appears that Ford used smaller lines on the Super Dutys and adapters to connect the lines to the various vacuum connections. Many of the adapters look like they are at the end of their life. Has anyone replaced these with standard vacuum lines (larger ID) and eliminated the adapters? Don't see why I can used standard lines, but not sure if they caused any issues. Thoughts?
Old Sep 27, 2011 | 04:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What lines are you referring to? The hub lines or the HVAC lines?
Old Sep 27, 2011 | 06:40 PM
jim0517's Avatar
jim0517
All of the vacuum lines. The rubber adapters that connect the plastic lines are failing. Rather than screw around hunting down vacuum leaks, I plan on buying a roll of hose and replace them all.
Old Oct 8, 2011 | 07:08 PM
jim0517's Avatar
jim0517
Found my problem. Damn squirrel chewed thru 3 vacuum lines and nibbled on the insulation on 4 wires. Used 7/64 inch vacuum hose to create splices on the hard plastic lines. Still need to replace some of the rubber adapters, but it's all working again.
Old Oct 8, 2011 | 07:21 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Glad to hear you figured it out.
'92 Ford
Jul 5, 2016 03:19 PM
GMan1
Jul 18, 2009 07:42 PM
95 F150 Dude
Feb 20, 2009 04:29 PM
Matt Wilson
13
Apr 5, 2005 01:27 PM
kameronth
1978 - 1996 Big Bronco
Jul 28, 2004 03:56 PM
