Broken Vacuum Lines
Old Feb 2, 2007 | 09:10 AM
tatetodd's Avatar
tatetodd
Broken Vacuum Lines
'93 F-150, 302
Contrary to my "if it aint broke..." philosophy, I decided to change out plugs/wires (after about 125K miles since last time). In changing out no. 1, I broke the little straw like vacuum lines (red & Blue/black?) leading to the coffee can/ vacuum reservoir. It wasn't hard ..just barely touching them snapped them clean. Becasue they were so very brittle I'm not sure they werent cracked or were functioning prior. Anyway, seems to be running about the same as before.
I have three questions.
How do I replace them?
What do I ask for from parts store?
What kind of trouble should I expect until I replace them?
Thanks a bunch for any advice, help or similar stories.
Old Feb 2, 2007 | 09:46 AM
teenagegearhead06's Avatar
teenagegearhead06
i broke those same lines and i just took some rubber tubes that were slightly bigger and stuck both ends of the lines in it and it works good.
Old Feb 2, 2007 | 11:38 AM
StillaKilla187's Avatar
StillaKilla187
I ripped all of my emmissions stuff (vaccuum lines, smog pump, carbon boxes, etc) out, and runs perfect, well actually better than before but whatever.
Old Feb 2, 2007 | 08:02 PM
mississauga's Avatar
mississauga
Most auto places sell small rubber vacuum hose in various inside diameters to match what you need to replace what you have.
Old Feb 4, 2007 | 09:48 AM
jonathandennell's Avatar
jonathandennell
I broke the same exact lines doing the same exact thing and thats what i did.. worked just fine if not better!
However, I left it alone for a while after I broke it and didn't replace it after it broke and I kept getting a Check Engine Soon light after running the engine for about 5 mins. Put the rubber tube on, light went away
Old Feb 4, 2007 | 03:38 PM
tripndrag's Avatar
tripndrag
Heat shrink works the best in my opinion. Heat shrink is cheap, the seal is perfect.
http://www.cardomain.com/ride/2559636/6
Old Feb 4, 2007 | 04:18 PM
dgeesaman's Avatar
dgeesaman
I saw in a couple of engine rebuild threads that it's a good idea to replace all of these when pulling the engine.
Is that the way to go, or is it better to make your own as you guys described?
Dave
Old Feb 4, 2007 | 05:00 PM
brown 4x4's Avatar
brown 4x4
If they're still in good shape I'd reuse them. My "younger" 95 still has a perfect harness and they aren't brittle at all. I've come across a few very good harnesses at junkyards too.
But if they are brittle and breaking all the time it's probably best to replace them. A homemade harness probably won't look or fit as good as factory, but may work better.
One thing I was always going to do is use air line for heavy trucks. The lines going to the transmission splitter are the perfect diameter and made out of hard plastic similar to our vacuum lines. I don't think they get as brittle over time though. I bought some awhile ago and it's really cheap. The rubber ends of our vacuum lines fit perfectly. I fixed the famous leaking white a/c recirc door line this way.
Old Feb 5, 2007 | 09:35 AM
tatetodd's Avatar
tatetodd
Thanks a bunch all.
This site has saved me money/frustration, taught me a thing or two about my truck and expy and made me laugh as well. I reckon this kind of collaborative information exchange is about the best thing going on the net.
Tater
Old Feb 5, 2007 | 10:45 AM
qman's Avatar
qman
I've used heat shrink and I've also pulled them off salvage trucks.
Old Feb 5, 2007 | 11:39 AM
gustang818's Avatar
gustang818
I used Dorman's Vacu-Tite! hard emission/vacuum tubing in 1/8" o.d. to replace mine. https://www.dormanproducts.com/ and search for part # 47417. Your auto parts supplier should also sell soft rubber vacuum connectors that slip over the line to hook the new and old lines together.
Old Feb 5, 2007 | 12:45 PM
countryboy4_1qt's Avatar
countryboy4_1qt
You can by the coffee can from LMC for around $40 one line has air going in to the "coffee can" and the other sucks the air out of the "can" so you can either replace it or just tie the vacuum lines up out of the way. Mine broke and before I got my new resevoir shipped I just put a piece of rubber hose in each of the lines forming a complete circuit. worked fine and my truck ran normal. 10 mpg with a 302 ...Love heavy trucks with underpowered engins
