3g clocking/ clock or counter clock nut thread
Old Feb 2, 2012 | 07:55 AM
70-360fe's Avatar
70-360fe
Tring to clock my 3g put can't get the nut off. I'm going to spray with pb blaster just wondering if retaining nut is counter clock direction or clock direction. I don't want to break my alternator, any other ideas. May have to cut off, thanks.
Old Feb 2, 2012 | 10:45 AM
70-360fe's Avatar
70-360fe
Got it, mounted on truck and gently used a 5ft pipe on the wrench. Don't know why this truck hates so much. Got to go get some new brushs.
Old Feb 2, 2012 | 03:58 PM
rustywheel68's Avatar
rustywheel68
impact wrench is great for this if you have one available.
Old Feb 2, 2012 | 06:07 PM
70-360fe's Avatar
70-360fe
Yea one tool I don't have. Found a nice 3g and did not want to damage it. I was perrty sure it was counter clock wise but it just did not want to move. Might be a good idea to look into impact wrench for future use, thanks.
Old Feb 2, 2012 | 07:48 PM
HIO Silver's Avatar
HIO Silver
yep, an impact is the way to do it. There is no substitute for the correct tool.
There is a shadetree way to do it but lemme add a disclaimer: PERFORM AT YOUR OWN RISK!
1. Insert a screwdriver into the case to jamb the internals. Choose a hole next to a rib on the front case that has alot of "meat" and be careful not to damage its internals.
2. Undo the pulley nut using a socket or combination wrench. Yes, it will loosen counterclockwise. Want to smack it with a hammer? Do so at your own risk!
Good luck!!!
bbsitum
1997 - 2003 F150
Jul 9, 2013 06:46 PM
hansont
Apr 18, 2008 03:57 PM
jrv7874
Oct 31, 2007 11:54 AM
cwb
Garage & Workshop
40
Feb 22, 2004 05:29 PM
inliner
Garage & Workshop
Mar 18, 2003 05:37 AM
