knocking 390fe
Old Jan 31, 2012 | 10:35 PM
joogie22's Avatar
joogie22
knocking 390fe
i have a 390 in my 77 f150. the motor was "rebuild" or so the guy i got it from said it was. i got it all together, and started to drive it. things were goin great on my way back from my 2 mile test drive. untill i heard a lot of valve noise. hooked up and oil pressure guage i was only getting 10 psi at 2000RPM. i dropped the pan and i just put the high vol. oil pump in tonight and still have a now LOUD knock on the driver side top end.. any ideas???
Old Jan 31, 2012 | 11:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is the knock crank speed or cam speed? Cam speed is half the crank, if that helps.
Otherwise, many times with an FE if there is a knocking sound on the top end it's usually a bent pushrod.
Josh
Old Feb 1, 2012 | 12:57 AM
joogie22's Avatar
joogie22
well im gettin about 4 knocks per sec at idle. around 1000 rpm so im guessin a cam speed knock. dam this motor stuff im a body man give me a welder and some bondo im right at home. motors are like speakin chinese to me....
Old Feb 1, 2012 | 02:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1976 was the last year for FE engines in F100/350's, so if your 1977 has a 390, it was swapped in.
Do not believe a single word a seller claims! Do some research before you buy. Private sellers can lie just as well as used/new car dealers, lawyers...and politicians.
And, do not assume it's a 390, because on sale day, 360 engines magically become 390's! The bore is the same (4.05"), the stroke is not the same.
Stroke: 360 = 3.50" / 390 = 3.78."
Old Feb 1, 2012 | 04:08 PM
joogie22's Avatar
joogie22
well he had paper work for the 390 block and the work to build it its bore .30 over and has mustang heads on it the block its self was out of a 65 merc, trans and transfer case from a 76 bronco. the truck sat for about 10 years after he had the work done i didnt know this till after starting it a few times. when i dropped the pan to replace the oil pump there was about an 1/8" of sludge on the bottom of the pan. and like i said the knock sounds like its the front driver side but its on the top im gonna look into a set of push rods and see if that takes care of it..
Old Feb 1, 2012 | 04:33 PM
wyckedcombo17's Avatar
wyckedcombo17
Before you throw parts at it, pull the valve covers AFTER the engine has been running. You don't need to drive for 2 hours and pull them while its scalding, just make sure that the lifters haven't bled down. Make sure that all of your rocker arms aren't freely flopping around and are properly torqued. If that doesn't solve it, then pull your pushrods and see if any of them are bent, like Josh said. Josh, Sleepy455 and a couple others on here (can't think of their handles) are pretty dern knowledgeable about the FE's.
Pushrods are a valvetrain issue, which would be half cam speed as indicated before. Most valvetrain issues aren't a "knock" but are more of a "tick".
Old Feb 1, 2012 | 04:44 PM
Bullitt390's Avatar
Bullitt390
The funny thing about FE pushrods going thru the intake as they do, if something binds and one gets bent it makes a very noticeable "knock" sound as it pounds and scrapes the pushrod bore.
Pretty easy to pull the suspect valve cover and have a looks-see. you can even run the engine briefly with valve cover off to help diagnose.
Josh
Old Feb 1, 2012 | 05:19 PM
OldStyle's Avatar
OldStyle
Rusty Roller
I'm not a expert on 360/90 engines but can't you just bring each cyl up to tdc and rotate the push-rods by hand to see if there is any wobble? They should rotate straight and true visibly without actually pulling the rocker assembly and removing the push-rods? Just a thought; I could be mistaken.
Old Feb 1, 2012 | 05:24 PM
Bullitt390's Avatar
Bullitt390
Yeah, actually most of the time if the pushrod is the culprit once the valve cover I off you'll see the pushrod body scored pretty bad and would likely notice the bent rod too.
That's why I lean towards a bent rod versus a collapsed lifter which would be a loud tapping and not a knock.
Could be something weird too like the oil baffle under the VC came loose an is just slapping around.
Old Feb 1, 2012 | 05:25 PM
Sleepy445FE's Avatar
Sleepy445FE
That's a good point. I picked up a 360 for scrap prices from a guy who heard it "knocking" and didn't want to do a rebuild. He hadn't done any investigating and just assumed that because it was a knock and not a tick it was something in the bottom end.
Loosened the rocker shaft and pulled the pushrods and lo and behold ones bent. It was longer than the rest for some reason. You could see where it had made contact with the pushrod bore causing the sound. Cheap fix and a decent profit when I sold it for very little work.
Old Feb 1, 2012 | 06:35 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well, another thing to look at is those rocker assemblies. One bolt is special to let the oil through and it had to be in the right place. One more thing is make sure the oil holes are down on that rocker shaft and not up. I have seen the shaft put in with the holes down and it makes for some strange symptoms. As does the wrong bolt in the wrong hole, oil is restricted. If you find one look for the other. Last but not least is look at the valve lash. People take this for granted on hydraulic cams, but on fords there is a spec I have found only in the factory manual that states to assemble the engine and compress the lifters and measure the clearance between the valve stem and the rocker tip. If the heads or block were milled or the cam journals bored or the valve stems are taller, this number will be altered. If it is too little, the valves could never close and if it is too much, the geometry on the valve stems is wrong and instead of pushing straight down on the valve stem, it pushes more sideways and ruins the valve guides.
Old Feb 1, 2012 | 07:26 PM
Sleepy445FE
Originally Posted by F-250 WARHORSE
Well, another thing to look at is those rocker assemblies. One bolt is special to let the oil through and it had to be in the right place. One more thing is make sure the oil holes are down on that rocker shaft and not up. I have seen the shaft put in with the holes down (I think you mean UP) and it makes for some strange symptoms. As does the wrong bolt in the wrong hole, oil is restricted. If you find one look for the other. Last but not least is look at the valve lash. People take this for granted on hydraulic cams, but on fords there is a spec I have found only in the factory manual that states to assemble the engine and compress the lifters and measure the clearance between the valve stem and the rocker tip. If the heads or block were milled or the cam journals bored or the valve stems are taller, this number will be altered. If it is too little, the valves could never close and if it is too much, the geometry on the valve stems is wrong and instead of pushing straight down on the valve stem, it pushes more sideways and ruins the valve guides.
Here is an article on removing/installing non adjustable FE rocker systems and checking valve clearance and lifter preload.
https://www.ford-trucks.com/article/idx/8/106/article/FEs_That_Bend_Pushrods_A_Dirty_little_Secret.html
Old Feb 1, 2012 | 09:08 PM
F-250 WARHORSE
I know little of FE blocks but have read lots and rebuilt a few, but a small problem can make some strange noises and symptoms, like the rocker shaft being upside down eliminates the oil restriction and iol flows too fast and can't drain out of the valve covers so it starts burning oil through the valve seals, and you get a tick due to the clearance being too great from the oil in the top rather than the bottom. I'm sure it is simple, but finding it is half the battle.
Old Feb 1, 2012 | 10:13 PM
1972RedNeck's Avatar
1972RedNeck
The serial break was in '77 wasn't it? All hiboy's had FE's, right? I have seen a few '77 (seller claimed anyway) hiboy's with FE's.
Old Feb 1, 2012 | 10:26 PM
turbohunter's Avatar
turbohunter
Happens all the time. Check this first.
