Mystery Wire
Old Jan 31, 2012 | 07:58 AM
caokgafamily's Avatar
caokgafamily
Mystery Wire
Hey guys I appreciate your help!
I have fixed everything from the squirrel damage except for 2 wires. The squirrel chewed them off and I have no clue what they go to. I inspected the area VERY good looking for the other ends.
The wires are located behind the passenger side battery about 10" on top of the wheel well right next to the outside fender wall. It looks like 4 wires go into this black plug connector then there is another black plug connector that connects to it with two each green and brown wires that come out. The squirrel chewed the green and brown wire up with little nubs left. I think the wire may loop back to itself?
I have looked all through the wiring diagrams and can't find anything on these.
Side note: After the squirrel prob my altenator and a battery went bad, I replaced the altenator and the bad battery, the guy said I was getting a draw? from something when everything was off 3 amps?
Everthing has been good but this morning it seemed like the battery was weak again, lights dim, but when I reved it up they got bright again.
Thanks for any input.
Steve
Old Jan 31, 2012 | 08:36 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I think I found the plug you are talking about. If it is mounted to the fender between the battery and the air box, lime green wire with a red/brown stipe it is looped.
Old Jan 31, 2012 | 08:41 AM
caokgafamily
Yes Shane that sound like the wire, when you say air box are you talking about that black oval plastic thing, if thats the airbox then yes it betwwen it and the battery. It's actually closer to the airbox just a little. Does your wire loop back to itself? 2005 6.0
Thanks,
Steve
Old Jan 31, 2012 | 09:37 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Thanks,
Steve
Yes, I am not sure of the technical term for the box, but it holds air for the 4x4 and a/c vents... Yes definitely looped back. I have a pic if you need me to text it to you....
Old Jan 31, 2012 | 10:03 AM
caokgafamily
Shane,
Your the MAN!!! Yes I would like a text pic 478-228-1711.
I lived in Choctaw Ok before we moved to Ga.
Thanks,
Steve
Old Jan 31, 2012 | 10:07 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Shane,
Thanks,
Steve
Not a problem, the pic has been sent. Extra glad to help a fellow Okie!
Old Jan 31, 2012 | 10:15 AM
caokgafamily
Where is Chelsea OK? My dad's family came from Moore OK, I have some good friend's who live all around OKC.
Steve
Benchwrench
Oct 26, 2016 03:12 AM
htownoag
Feb 5, 2016 08:47 AM
LonnieD
Apr 5, 2013 07:44 PM
bensr
Jul 1, 2005 11:54 PM
Fcal
Jul 14, 2004 09:57 AM
