chewed wire ?!
Old Sep 3, 2015 | 02:14 PM
Benchwrench's Avatar
Benchwrench
chewed wire ?!
A mouse or worse, a squirrel has chewed into a small green wire loop that's located under the passenger side battery on my '06.
It looks like a green wire w/ brown stripe. It's a jumper wire plug.
Anyone know what circuit they chewed?
again, the plug/ jumper is a GN/BN loop.
Stupid Squirrels
Old Sep 3, 2015 | 08:30 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Thats why i have about a dozen bounce sheets all over my truck!
Old Sep 4, 2015 | 08:02 AM
Benchwrench
The reason how I found the nawed wire is because the battery has an insulative wrap that I found to have a hole chewed in it. I had to remove the battery to fix the wrap , that's when I discovered this chewed gn/bn loop wire on a plug.
It looks like it was designed for an option that would plug into a round 6 pin? plug. The 5-6 wires that feed this plug are small wires that look that they would just carry a sensor signal or possibly an amp or two. This comes out of a larger harness that is strapped all along the passenger side fender.
Old Sep 4, 2015 | 09:57 AM
mhoefer's Avatar
mhoefer
Second alternator circuit, snowplow prep I don't know for sure, but I remeber it under there. Yahiko with all his diagrams might be able to pin that down. Shrink tube is your friend.
Old Sep 4, 2015 | 12:45 PM
Benchwrench
I did solder & heat shrink the repair then covered & taped with an inch of wire loom.
maybe need to spray around with ghost pepper or something.
Since the wires were so small, didn't think the second alt. option would apply.
Old Sep 4, 2015 | 04:10 PM
microbc's Avatar
microbc
I may be wrong but I believe that it is a wire for the daytime running light module that could be added to US trucks (it comes standard in Canada).
As you probably have noticed, we here in the US don't typically have daytime running lights on our SuperDuty trucks.
Old Sep 4, 2015 | 04:20 PM
Yahiko's Avatar
Yahiko
If you have any idea on what I need to be looking for I can check diagrams.
I have seen that jumper and don't have any idea what it hooks up to what.
Most of the DLR is in the BJB and the rest uses the headlight lamps at a lower voltage. So that little jumper
is most likely not part of that. M-chan or Cheezit would likely know what it is. Need to ask one of them.
Sean
6.0L Tech Folder
Old Sep 4, 2015 | 05:57 PM
Kdawg89's Avatar
Kdawg89
I don't know what the OP wire is but I don't think it is from the DRL option. My truck is from canada so it had the DRLs until I unplugged the module which is on the driver side of the vehicle.
Old Sep 4, 2015 | 06:51 PM
gwh1bass's Avatar
gwh1bass
It's getting to be that time of year where the critters around me are getting busy. Over the years they have pretty much chewed up all the insulation in my 6.0 engine bay.
I have found acorns stashed in nooks in crannies in the engine.
I have found grass and leaves crammed in front of the air filter, once they even began chewing on the air filter.
Have found one wire where the began gnawing through the insulation on the passenger side.
Sure would like to find a sure fire way to keep the critters out of the engine bay, as Ex stays outside in the driveway.
Has anyone put some kind of screen at the cold air intake to the air filter? Stock setup.
Old Sep 5, 2015 | 07:10 AM
m-chan68's Avatar
m-chan68
DUAL ALTERNATOR PLUG IN.
Old Sep 5, 2015 | 02:07 PM
4x250cx's Avatar
4x250cx
I live in rodent central, what's worked well for me is propping the hood open 12 16 inches, with a piece of wood, pvc or whatever, stopped my rat problem, good luck
Old Sep 5, 2015 | 03:26 PM
Yahiko's Avatar
Yahiko
I knew you would have the answer.
Thanks for the info.
Sean
6.0L Tech Folder
Old Sep 6, 2015 | 10:49 AM
Benchwrench
Me too,
thanks Boobie Man.
(to our new Super Hero as he hops back on his Hooter scooter)
Old Sep 6, 2015 | 10:51 AM
Benchwrench
https://www.ford-trucks.com/forums/8...-filter-3.html
I feel your pain, see post #35
Old Mar 10, 2016 | 04:02 PM
gwh1bass's Avatar
gwh1bass
Well spring has somewhat sprung here in Michigan and I find new nesting material in front of my air filter this week. If I drove it everyday it might not happen.
