fuel filter leak
Old Jan 28, 2012 | 08:56 PM
IDI guy's Avatar
IDI guy
fuel filter leak
My fuel filter is leaking from the bottom of the water release valve is there an o ring in there that that valve seats into? Any ideas?
Old Jan 28, 2012 | 10:01 PM
bashby's Avatar
bashby
you can get a filter that replaces the 2 piece with a one piece. NAPA carries them but i dont know the part #
Old Jan 29, 2012 | 01:19 PM
fuzzy1626's Avatar
fuzzy1626
Yes there is. It's more like a slice of rubber line. There is also a valve core in the bottom that could leak if some trash were to get in it while open. It opens when the wheel is turned all the way up. Remove The drain bowl from the filter. I put the wheel lightly in a vice and used a wrench on the inside part of the valve to separate it. Took mine to IH and they found one in a box of odds and ends. LOL. When you see how it works you'll see that it's not good to overtighten the wheel after draining. Hope this helps.
Old Jan 29, 2012 | 02:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
i use the napa one piece filter. no more leaks from the water separator!!
Old Jan 29, 2012 | 03:08 PM
IDI guy's Avatar
IDI guy
Ok so if I use the one piece what do you do for a water seperator?
Old Jan 29, 2012 | 03:53 PM
fuzzy1626's Avatar
fuzzy1626
The one piece has the water seperator built in. And you can get them with the WIF sensor also, but they cost more than the ones that use the stock bottom drain.
Old Jan 29, 2012 | 04:47 PM
tjc transport
i ain't rite
yup. the one piece has the drain in it. but in 24 years and 493,000 miles, not once have i ever had to drain the filter.
Old Jan 29, 2012 | 05:18 PM
IDI guy's Avatar
IDI guy
Ok I called napa and they have both different kinds I will pick up the one with the drain tomorow. I only had water in my fuel one time it was durring a blizard on pyramid lake in NV a guy with a white beard drove up in a red bullnose ford diesel with a fuel tank on the back he took my fuel filter out of my 84 rinsed it out with fresh red diesel in the snow had me start it up he said merry christmas and drove off. Santa Claus drives a ford I guess lol! You can't make this stuff up.
Old Jan 30, 2012 | 05:12 PM
tje2015's Avatar
tje2015
hahaha you really cant make that **** up.
Since i have owned this ford I have had the greatest experience with help from people.
I could be sitting with my Eclipse pushed off the side of the road at a stop light with a dead battery waving jumper cables at every **** on the road and no one would stop...
Hell in this ford the only time i was on the side of the road I had 3 people stop to see if i needed help, and it was RAINING....
There are no people like Ford people.
Old Jan 30, 2012 | 05:14 PM
1990DieselQuadDually's Avatar
Have been running Baldwin 1 piece filter/separator for years without a problem.
stormyrider
Jul 4, 2009 01:02 PM
57trailer
Aug 3, 2008 12:14 AM
Wings
Nov 23, 2007 08:25 PM
archangel
Jul 29, 2007 06:09 PM
vettdvr
Apr 19, 2007 07:51 PM
