Sponsored by: Real Truck
oil smell
Old Jan 27, 2012 | 07:47 PM
slammer's Avatar
slammer
oil smell
Sometimes when I stop my truck, I smell oil. Kind of like when oil drips on the exhaust. I cant see where its leaking onto the ground at all. Only smell it occasionally and always when the truck is warmed up. Any ideas?
thanks
Old Jan 27, 2012 | 09:17 PM
Bigpipes 35's Avatar
Bigpipes 35
Valve cover gaskets leaking maybe , do you see any oil on the heads ??
Old Jan 27, 2012 | 09:27 PM
Quad Racer's Avatar
Quad Racer
When I smell that in traffic I look around and it never fails, a GM product.
Does she use/loose much oil between changes?
Old Jan 27, 2012 | 09:33 PM
Kajtek1's Avatar
Kajtek1
Since we don't know the engine, we can guess forever.
On both my 7.3l it was oil cooler orings.
Old Jan 28, 2012 | 03:41 PM
slammer's Avatar
slammer
Sorry...v-10....2003
Old Jan 28, 2012 | 06:16 PM
vthao's Avatar
vthao
It's most likely going to be your valve cover gaskets. These sit perfectly so that when they leak, they drip onto your exhaust manifolds, hence the burning oil smell.
Old Feb 3, 2012 | 01:38 PM
slammer's Avatar
slammer
I looked at the engine and the drivers side is clean and dry but the passenger side is oily...kind of like a combination of dirt and oil...its all over the valve cover, not just on the side.
If its just the valve cover leaking, I am okay with that but I want to make sure it isnt anything more serious. Is there anything that it could be besides teh valve cover. the truck runs great and there is real good oil pressure.
thanks
Old Feb 3, 2012 | 03:25 PM
Bigpipes 35
thanks
I would say you are dealing with a valve cover oil leak which is fairly common. If you are smelling it burning then its coming out above the exhaust manifolds. No worrys drive her till you get sick of the smell and then have her fixed..
Old Feb 3, 2012 | 09:16 PM
slammer's Avatar
slammer
I got to the bottom of the smell.... its a leaking power steering hose and/or pump. I crawled into the engine compartment and noticed it.
Gonna clean up the hose and then see if its just the hose or if the pump is toast...
thanks for all the advice..I do appreciate it.
Old Feb 3, 2012 | 09:45 PM
Bigpipes 35
Glad you figured it out and thanks for posting back...
Cothfotmeoo
Sep 3, 2016 11:10 PM
echavez1981
2004 - 2008 F150
Jul 1, 2007 09:54 PM
F0rdF0rever
1983 - 2012 Ranger & B-Series
18
Nov 19, 2005 07:34 PM
lynxcat
Oil & Lubrication
Mar 8, 2004 11:48 PM
86bronco2jeff
Oil & Lubrication
Mar 25, 2003 11:32 PM
