Lost all the oil
Old Sep 3, 2016 | 09:34 AM
Cothfotmeoo's Avatar
Cothfotmeoo
Lost all the oil
It's a 1991 Ford F250 5.8L 4x4. I just changed the oil a week before and did it correctly (like any 8yo should be able to do). Was driving it slow on some back roads when I suddenly lost all oil pressure and started hearing a faint click click click sound so I pulled it over and turned it off. The oil dipstick registered nothing but I couldn't find a leak, oil filter is on tight, oil plug is on tight, and all the hoses looked fine. Put some more oil in and ran it for a bit to test it, still heard the click sound but still couldn't see a leak or smoke or anything. Still have no oil registering on the dipstick.
Old Sep 3, 2016 | 10:12 AM
roboto65's Avatar
roboto65
Well it went somewhere, either out the tailpipe or a leaking rear main seal or front seal or well any other gasket, but you should be able to see any of those with a leak that big keep adding oil till it registers on the stick but 5 quarts should suffice.
Old Sep 3, 2016 | 08:08 PM
jaagen's Avatar
jaagen
How about the coolant. Not sure if this us correct but what about oil cooler adapter.
Old Sep 3, 2016 | 10:51 PM
The_Drew's Avatar
The_Drew
On my 460 I had a similar situation, turned out the block off bolt for the deleted oil cooler got loose and was spraying oil everywhere. Including on my exhaust which led to a big cloud of smoke behind me. Couldn't find it until I turned the truck on and looked around the engine bay.
Old Sep 3, 2016 | 11:10 PM
mrollings53's Avatar
mrollings53
I've done this once where I forgot to remove the old oil filter gasket before spinning on the new filter. Coupled with the odd desire to push my car out of the garage resulted in me spilling it all on the ground, and driving a couple miles on the freeway before seeing the oil light flash.
jcoiler
Sep 12, 2015 12:37 PM
Mike Hannahs
Oct 10, 2013 08:29 PM
echavez1981
2004 - 2008 F150
Jul 1, 2007 09:54 PM
F0rdF0rever
1983 - 2012 Ranger & B-Series
18
Nov 19, 2005 07:34 PM
Itsmejoe231
1997 - 2003 F150
Aug 31, 2005 04:11 PM
