Aviator ABS sensor test procedure
Old Jan 23, 2012 | 07:47 PM
sgtscrounge's Avatar
sgtscrounge
Bought an '04 Aviator 2wd on Saturday. ABS light is on almost all of the time, but it has turned off a few times.
Pulled a C1155 code. I removed the left front sensor, and there was no dirt, metal, debris, etc in the hole. Before I buy a new sensor, is there a test procedure to follow on the old sensor??
Old Jan 23, 2012 | 09:26 PM
steve(ill)'s Avatar
steve(ill)
When you start the motor, the computer runs a continuity test to see if all the wires are connected. AFter your moving the computer checks that sensors all read "about" the same speed. If the light is on at idle, you sensor is broke. If the light comes on while driving, it may be weak or not setting square in the hole, or too far away from the teeth... I bet weak.
Old Jan 24, 2012 | 09:13 PM
sgtscrounge
New Borg-Warner ABS sensor on left front= ABS light stays off.
Tomorrow night, change the differential lubricant !
mikren
1997 - 2003 F150
Nov 23, 2018 09:46 AM
spinella
Sep 10, 2011 03:51 AM
gdombroski
Nov 10, 2007 09:36 PM
afirestop0
1997 - 2003 F150
Nov 9, 2005 12:56 AM
