Just a little update to this thread... I was finally getting around to installing the clutch yesterday, only to realize that the FLANGED-HEAD bolts I picked up several months ago interfere with the clutch. (i.e. the flange bottoms out and binds against the side). Off to Ace Hardware, hoping to find six Allen-head 3/8-16 x 1" bolts.
One other realization I had yesterday which concerned me for a bit... There's no locating dowels for this flywheel/clutch and it's just the bolts (together with the centering tool) that center the clutch to the flywheel. All the other applications I've worked with use 3 dowels in the flywheel to locate the clutch.
