1995 F150 4.9 clutch 10" vs 11"
Old 03-20-2016, 06:29 PM
bmxerbrett's Avatar
bmxerbrett
bmxerbrett is offline
bmxerbrett is starting off with a positive reputation.
I ordered parts from Rock Auto before I had the transmission off. I ordered a 10" clutch from them. I installed the pilot bushing from that kit. When I went to install the clutch I noticed to bolts were to large to fit through the new pressure plate holes. Dug my old clutch out of the trash and noticed it was actually larger...
Should I risk the return to RockAuto or just keep the clutch I bought? Only issues is I have no idea what size bolts I need in order for it to fit on the flywheel.
Old 03-20-2016, 08:36 PM
88n94
88n94 is offline
88n94 is gaining momentum as a positive member of FTE.88n94 is gaining momentum as a positive member of FTE.
From what I have read on these forums, the flywheel is drilled to use either a 10 or 11 inch clutch. Is there another set of holes a little farther in that are smaller diameter? I'm thinking probably 5/16" diameter is what the 10 inch clutch would take and the same length as the bolts holding your other pressure plate on.
I just used a 10 inch clutch in my '88 F-150 and it serves me well. I never paid any attention to the extra holes in the flywheel.
Old 03-20-2016, 09:03 PM
bmxerbrett's Avatar
bmxerbrett
The 11" uses 3/8" bolts. The 10" uses 5/16" 18 thread bolts. Yes the flywheel can use either. I ended up just going to Home Depot a bit ago and bought some bolts so I can use my 10" clutch and not have to deal with the hassle of shipping my other one back to rock auto.
Old 03-20-2016, 09:33 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Originally Posted by bmxerbrett View Post
The 11" uses 3/8" bolts. The 10" uses 5/15" 18 thread bolts.
Is this what you fingers typed but your keyboard posted?
11" = 3/8"
10" = 5/16"
Old 03-20-2016, 11:01 PM
bmxerbrett's Avatar
bmxerbrett
11" = 3/8"
10" = 5/16"
Haha yep. I just edited my post
Old 03-21-2016, 11:35 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.
Fwiw, rock auto is in the business of shipping parts and are generally very good with returns.
Nathan Koeppe
04-13-2017 08:46 AM
four-sixty-power
03-19-2017 01:44 AM
Norma stitz
10-23-2016 04:13 AM
82fordowner
16
06-23-2016 03:15 PM
ctubutis
'80-'86 HOWTO's
02-08-2011 08:51 PM
Quick Reply: 1995 F150 4.9 clutch 10" vs 11"
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
