factory tach
Old Jan 22, 2012 | 01:37 PM
spikinfool05's Avatar
spikinfool05
factory tach
rumors around the bone yards here is there was a factory tach for these trucks is that true? if so where was it?
Old Jan 22, 2012 | 02:07 PM
fmc400's Avatar
fmc400
MSEE
I thought I read there was a tach available for commercial heavy-duty trucks (which came with the earlier-generation dash anyway), but nothing for F350 and under.
Old Jan 22, 2012 | 02:14 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Only aftermarket, OTC tachs were available for these trucks, no factory dash installed units.
Josh
Old Jan 22, 2012 | 02:20 PM
MikePacey's Avatar
MikePacey
The rumor I heard was it was a hood tach. But as far as I know of didn't Ford not offer a hood tach on anything except for like the torino? Or not even at all?
Old Jan 22, 2012 | 02:25 PM
Bullitt390's Avatar
Bullitt390
Hood tachs are aftermarket, dealer installed items. Only vehicle factory equipped is likely the Pontiac GTO. No Ford Torino, Mustang or otherwise came with a factory hood tach.
As for the large trucks I don't know. Some of those trucks had factory hood scoops though!
Josh
Old Jan 22, 2012 | 06:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No factory tachs below F500's
Here's an F500 dash w/ tach, note the tach max's out at 3,000 RPM.
Old Jan 22, 2012 | 11:12 PM
spikinfool05
got the same dash in a old grain truck. thought about takin it out and puting it in my 78.
Old Jan 22, 2012 | 11:44 PM
RunninD's Avatar
RunninD
Would it even go in? I loved the dash out of my '64, which was the same, but didn't know if they would fit in a dent. If so it would be awesome!!!!
Old Jan 22, 2012 | 11:56 PM
spikinfool05
dont know why it wouldnt the cabs are almost the same. doors are the same and ive took cab corners out of some for rust repair.
Old Jan 23, 2012 | 04:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 Passenger Cars, F100/350's, Bronco's & Econolines:
Universal "fitz-all" FoMoCo accessory tachometers, came with steering column mounting bracket.
D3AZ-17A326-A .. 6,000 RPM Faria Tachometer, 250 degree dial.
D3AZ-17A326-B .. 9,000 RPM Faria Tachometer, 250 degree dial.
Beginning in 1961, there were all sorts of accessory tachs available. Most were either marked SUN, or had crossed flags, or the Cobra emblem. Some mounted atop the dash, some on the steering column.
Initially listed in Ford High Performance Catalogs that feature the Cobra emblem on the cover. Then in the Motorsport Catalogs that were introduced in 1969.
I have no Motorsport Catalogs, but do have the original Hi-Po Cobra versions that cover 1961/67 and 1968.
And, the 1965/72 Ford Passenger Car Parts Catalog lists this little charmer: 1965/71 all FoMoCo vehicles =
C9AZ-17A326-A .. 8,000 RPM Tach / Hood Mounted / Obsoleted 11/1973.
btw: I don't recall if GTO's (Gran Turismo Omologato aka Garbage Truck Option) came with a hood mounted tach...or not, but I do recall seeing some Firebirds with this feature.
1964 Pontiac GTO considered by many as the first muscle car and was the brainchild of Pontiac executive John Z. DeLorean.
Old Jan 23, 2012 | 06:37 AM
Bullitt390's Avatar
Bullitt390
Pontiac GTO "Judge" factory installed hood tach...
Josh
Old Jan 23, 2012 | 09:18 AM
spikinfool05
ya the man i talked to said it was part of the speedo. didnt know if it was true or not.
Old Jan 23, 2012 | 07:45 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Nope, not true. Be nice if there was a factory tach though.
Old Jan 23, 2012 | 08:00 PM
spikinfool05
grain truck dash here i come
GM4WALLS
13
Jul 14, 2021 10:26 PM
Eddiec1564
74
Jun 23, 2017 04:46 AM
fitzmotor
Sep 18, 2011 08:13 PM
smallblock351w
Apr 7, 2006 10:33 PM
