factory tach
Old Apr 6, 2006 | 07:19 PM
smallblock351w's Avatar
smallblock351w
factory tach
for the factory tachs in these trucks where they all the same or was there a different one for a 6 cylinder and 8?
Old Apr 6, 2006 | 08:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Depending on year they had different ones.
The most common is the 0 to 6000 RPM tach. The tach has two grounding posts. One for ground, and the other is only grounded if you have a V8.
There is also a tach that reads 0 - 3500 RPMs for the diesel trucks. I have seen these used in the 300s as well.
Old Apr 6, 2006 | 09:01 PM
smallblock351w
k thanks thats kinda what i thought. but needed to make sure
Old Apr 7, 2006 | 06:01 PM
Nathane's Avatar
Nathane
sorry for the hijack... but do you just plug it in, and it will work??? Or what?
tks alot
~Nate
Old Apr 7, 2006 | 06:21 PM
smallblock351w
okay you run the wire that used to go to the coil where it said test tach i believe over to the msd where it has the tach wire end. then in the harness there is a black wire with green dots that you have to ground its over by the original ignition box. you cut that out and ground it to the vehicle. also at first i just tried grounding it but had the old ignition box plugged in and ti gave a false tach reading so its best to just totally remove the old ignition box if you havnt. hope i explained that right but it is working properly now
Old Apr 7, 2006 | 10:25 PM
81-F-150-Explorer
If you read the tips and tricks in the sticky on top, installing a factory tach in a vehicle without one is covered there.
Basicly if you have oil and ammeter gauges, installing the factory tach is plug and play.
you need to get yourself a cluster with a tach, and go from there.
The cluster of a 1980 is different than the cluster on a 1981-1986 so if you have a 1980, you need to get a 1980 cluster. If you have a 1981 to 1986, you can use one out of a 1981-1986.
The 1980 is not compatible with any other year, because the printed circut in back of the cluster is different than on 1981-1986s
Old Apr 7, 2006 | 10:33 PM
smallblock351w
opps my apologys part of my trouble and me slightly mixing my threads to one i had previously posted is how to wire it with a msd. your right its basicaly plug and play for a factory iwth the factory ignition
reamer
Apr 9, 2012 09:10 AM
spikinfool05
13
Jan 23, 2012 08:00 PM
critterf1
Jan 10, 2012 10:04 PM
topscrt
Feb 9, 2009 09:47 PM
15
Apr 13, 2008 05:18 PM
