Sponsored by: Real Truck
To fix smooshed cab, or replace?
Old Jan 19, 2012 | 06:16 PM
BioBurner's Avatar
BioBurner
I've got a 2002 F350 that was laid over on it's right side. I already changed the front passenger door, front bumper, grill-guard, and the bed (Here:https://www.ford-trucks.com/forums/9...pictorial.html). I still have to get a new passenger rear door. My original plan was to try to pull the dent out with a stud welder and a slide hammer, but my efforts were less than acceptable. My "Plan B" was to have a professional pull the corner of the cab square, cut out the dented sheet metal and weld in a new piece of skin. Recently I got to thinking that even if the bodyman is talented and thorough, I'm still going to not be satisfied with the finished product, knowing that my truck was wrecked. I've been kicking around the notion of buying a stripped cab, having it painted while stripped, then swapping it onto my frame. I figure that it would probably cost me about the same either way (admittedly with a lot more work to swap cabs), but I'll be a lot more satisfied with the swap option.
What advice do you have for me?
Old Jan 20, 2012 | 01:00 PM
SteveH-CO's Avatar
SteveH-CO
A cab swap seems like a tremendous amount of work - I think I'd have the right body guy fix the pillar area and leave it. Since you're in Utah, you shouldn't have huge rust issues with the newly welded in panel. In some states, you can hardly keep paint on a new panel that doesn't have factory primer on it. I don't see how the bodywork would be the same cost as a cab swap, with all the paint and labor - discharging your A/C, etc. If you had a free cab, the story might be different, however.
Old Jan 20, 2012 | 02:07 PM
cartmanea's Avatar
cartmanea
I just did a cab swap on my '03, and it was a huge amount of work. I made it a little worse by having sound deadening applied over everything in the old cab... Depending on your state you can run into problems with changing cabs because of the VIN tag. Looking at your pictures, it looks like a good candidate for just a new cab corner, but I can't tell if the roof or the overall cab shape is distorted or not.
Old Jan 20, 2012 | 09:03 PM
Psyclopse's Avatar
Psyclopse
As a veteran of quite a few cab swaps, and judging from what I can see in the pics, I'd fix the existing cab if it were mine. If it is done right, there would be no reason to be unsatisfied just because you knew it was wrecked. Technically, with all the new parts, it will still be a formerly-wrecked truck, right? A good body man will do it right for ya.
Old Jan 22, 2012 | 12:51 AM
BioBurner's Avatar
BioBurner
Thanks for talking me out of that! I'll just pay someone to fix it for me. I get no enjoyment from doing bodywork, like I do with mechanical stuff. That's probably where this wild hare came from.
Old Jan 23, 2012 | 10:38 PM
sand_fiend's Avatar
sand_fiend
A good body mans work will never be seen..
Old Jan 24, 2012 | 09:05 AM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT
As long as the roof skin is straight / no wrinkles doesn't look like too hard a fix. Alot easier / less headache than a cab swap.
FordTruckGuy96
May 18, 2015 09:34 PM
ericconn
Oct 18, 2013 09:47 PM
MadFrank81
22
May 28, 2010 09:05 AM
907ford
13
Jan 7, 2010 04:52 PM
johnny19
Paint & Bodywork
Jun 15, 2003 07:55 PM
