Rusty Cab: Fix or Replace?
Old Apr 10, 2010 | 11:44 PM
MadFrank81's Avatar
MadFrank81
Is it worth trying to save a rusty cab on these trucks or should I be looking to swap to a better one from a salvage yard or wherever? Just got me a truck and the cab appears to be from a '77 F350 and it's rusting in every corner (including the interior roof corners, water leaking in from roof clearance lights!). Floor pans are rotting out behind the seat as well.
Also just how hard is it to remove the cab from the chassis? (reg. cab) I just got my first garage so I have room to do stuff but I don't have a lot of equipment yet. i.e. stands, hoists, etc.
My fantasy is to just ship it off somewhere and let them restore the metal work and dip it, and paint it. But that's obviously not quite in my budget!
Appreciate any info/opinions!
Old Apr 11, 2010 | 12:00 AM
4x4cody's Avatar
4x4cody
i was first gunna say post a pic but after a read what was all rusty id say replace the cab itself!
Old Apr 11, 2010 | 12:10 AM
MadFrank81's Avatar
MadFrank81
Yeah, that's what I figure it's going to come down to. Was looking through the LMC catalog, they have everything short of the cab itself, too bad.
Old Apr 11, 2010 | 01:07 AM
montana_highboy's Avatar
montana_highboy
Yea from what you described i think a total cab swap is your best bet, 1 saturday, 3 friends, 24 beers and 7,894 four letter words and you're done
Old Apr 11, 2010 | 01:48 AM
4x4cody's Avatar
4x4cody
HAHAH
well said!
Old Apr 11, 2010 | 01:56 AM
ford to the bone's Avatar
ford to the bone
ford to the bone
i got two cabs that i will be willing to sell the one needs cab mount and the other is perfict shape
Old Apr 11, 2010 | 07:13 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
I would also go with the cab swap. While the rust issues that you can currently see are pretty bad (and justify the swap alone) there are other areas that are undoubtedly rusty as well. That rust just hasn't manifested itself in perforation or bubbles... yet.
Old Apr 11, 2010 | 08:06 AM
bucks77ford's Avatar
bucks77ford
I'd also look for a replacement. Even if you find one that needs cab mounts or cab corners or floor pans, that would be easier to fix than the one you have.
Old Apr 11, 2010 | 02:09 PM
Raymond's Avatar
Raymond
Veteran: Navy
Do a cab swap. The cab that came on my 76 was so rusty that replacement panels aren't made for all of the places I had rust. I got one cab that need new floors and cab corners, but kept looking and scored a cab from the west coast that only has surface rust. There are cabs in the northeast you just need to keep looking. The cab that I got was in Pa so it wasn't to far to go. Good luck on you search.
Ray
Old Apr 12, 2010 | 11:30 AM
FordmanShane's Avatar
FordmanShane
lets see how bad it is
Old Apr 12, 2010 | 11:34 AM
Kalve's Avatar
Kalve
I would just repair it
Old Apr 12, 2010 | 12:22 PM
Blue Rebel's Avatar
Blue Rebel
Replaced mine:
From this:
To this:
Rust free cab, box and doors.. got the fenders in the shed, just gotta find a good core support
Old Apr 12, 2010 | 02:18 PM
RedLesPaul's Avatar
RedLesPaul
Ford T The Bone, I see you are in Hagerstown. Do you still have those cabs you mentioned? I'm near Ski Liberty, and might be interested in one.
Old Apr 12, 2010 | 02:38 PM
ford to the bone
ford to the bone
yeah i got one
Old Apr 13, 2010 | 12:00 AM
73 ford guy's Avatar
73 ford guy
I took this pic just the other day. Its a good cab minus the corners and floor section in these spots. I figure its a typical rust spot on these and I've used cheap aftermarket china replacement cabcorners before but with the jumping and offroading style I do I collapse the thin sheet metal. I cut the entire section out on each side(2'x2' square holes) and started to fit in them today. Im using 1/16 galvanized pieces formed to the shape I need. The cab mount will be custom as well using 1/8 plate. I just need a good starting point with a good floor to be able to weld on the new mount. I figure if I change my cab again,which I'm sure I will in the next couple years after I smash this one, i'll be able to cut this section out and transfer over to the new one.
I'll post pics tomorow of my patch job I started to weld in tonite when I get time tomorow..
