on my 87. where the ttb ties to the hub area, what is the name of the support rod going from there back to the frame? I replaced the drivers side a couple years ago and now the pass side needs to be done. I just can't for the life of me remember what its called.
10-4... got to discussin it @ work after I posted this and another driver knew what it was from an old 7.3 he used to have....... 'preciate it guys... now for the fun task of fixin it... and I promise I will try to be on to harass more
Yep, theyre on most all ford coil spring ttb / solid axle front suspensions. They keep the axle stationary under the vehicle from moving forward/backward and rotating when you either drive the axle or apply the brakes.
