Newbie/ engine cooling problems
Old Jan 17, 2012 | 02:16 AM
Ford4Life7.3's Avatar
Ford4Life7.3
And welcome to FTE brendon.
Old Jan 17, 2012 | 06:13 AM
DIYMechanic's Avatar
DIYMechanic
Originally Posted by Leemakesmepee
Just weird past 2 days have been snowing and like 14 degrees. then today it was around 30 and did it. but aslong as it doesnt hurt anything. If she wants to heat up quicker doesnt matter to me.
Originally Posted by oldbird1965
Lee & Nate, I've never heard of the PCM asking for a higher idle during cold weather?
Mine only seems to do it when the temps are really cold (20 degrees or below). And it doesn't idle really high, it just idles at say 750 RPM instead of the 550 or whatever that it usually idles at. I'm not going to rule out the possibility that it may just be an HPO issue or something on my truck either. It romps a little at startup when it's really cold outside and then smooths out after it has been running a few seconds. It doesn't really bother me so I haven't messed with it. It didn't do that before the engine swap though so I don't know....
Old Jan 17, 2012 | 06:18 AM
DIYMechanic
Oh, and if anybody wants one to try, I have a 203* deiselsite thermostat that I will let go cheap. Had it in the '96 motor and couldn't use it in the '95 motor I swapped into the truck (long vs short stem thermostat). I really liked it. It seemed to warm the engine up quicker in the cold. Only used it for maybe 5,000 miles. It would have to go into a '96 or '97 truck. Send me a PM if someone is interested.
Andy's7.3L
Aug 15, 2012 12:17 PM
fordtrucklover94
Jan 6, 2008 08:35 PM
tommy55925
Feb 7, 2007 01:06 PM
amsrus
1997 - 2003 F150
Oct 30, 2006 08:42 PM
jduhoski40
Oct 21, 2003 07:39 AM
