HELP, No heat...
Old Oct 19, 2003 | 09:53 PM
jduhoski40's Avatar
jduhoski40
HELP, No heat...
Ok, I have a 98 for explorer. When the temperature outside is 40 or lower I get no heat. The temperature gauge hardly moves up at all, especially when going down the expressway. I changed the thermostat but that did not do much. It still does not put out heat when its cold outside. However, if i am driving around town when its cold out the temp gauge goes up and i get heat. I thought the thermostat would have fixed this??? What should i do next??
Old Oct 19, 2003 | 10:32 PM
c96drumm's Avatar
c96drumm
Maybe you got a bad new thermostat. Happened to me once.
Old Oct 21, 2003 | 07:39 AM
Blly177's Avatar
Blly177
did you put the gasket in with the new thermostat
