Can I patch this much rust?
Old Jan 15, 2012 | 09:14 AM
Dave145's Avatar
Dave145
The bed of my '78 is about 1/3 gone from the left fender out. It's about a 3-4 foot long hole and its 2 feet at the widest. I saw some replacement panels on ebay, but i don't know if they'll fit. Is there a way to replace just the bed floor? I need some suggestions because I'm lost.
Old Jan 15, 2012 | 09:20 AM
earthquake68's Avatar
earthquake68
The bed floor can be spliced in from a newer truck. (the floor is VERY similar in a '80-'96) Just make sure to leave the braces intact and split the spot welds clean. So, to answer your question, yes, it can be fixed. At least it's the easiest place to patch. I didn't say it would easy, or even quick, BUT it sure can be done. Depending on where you are, decent beds can be almost impossible to find, so you have to work with what you have.
Old Jan 15, 2012 | 09:31 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Complete bed floors (long bed) with bracing are available from LMC and National Parts Depot.
Old Jan 15, 2012 | 09:45 AM
Dave145's Avatar
Dave145
Up here in Wisconsin, an older truck with a solid bed is considered rare. LMC does look like my best bet, but I'm not sure how much I can spend on a bed. On that note, can I replace the bed floor but leave the bed sides on? If i try to take off the sides, the bed braces are definitely going to break. one already broke just on the drive home due to the rust.
Old Jan 15, 2012 | 09:50 AM
earthquake68
That's what I was saying, yes you can just replace the bed floor. I would tack weld braces side to along the top of the bed sides to hold everything in shape while you cut away the bottom of the bed. Once you cut the floor out, you can patch/replace the braces. Then just weld the floors back in. It sounds like a rusty mess you have there. That's why I suggested finding a newer bed. They used galvanized metal and hold up much better than the older beds do. ....and the thicker factory metal is better than the Chinese made repair panels.
Old Jan 15, 2012 | 10:04 AM
Dave145's Avatar
Dave145
That's what I've been trying to do for a while. The problem is finding a light brown bed with the silver trim on it. I could get a black one and get a paint job, but I'd rather keep this as cheap as possible. Thanks for your help because i was completely lost before this.
Old Jan 15, 2012 | 10:10 AM
earthquake68
I'll offer, if you can find a bed that's good, paint will be the EASIEST thing to change. Cutting out and replacing the bed floor and braces is labor-intensive and time consuming. Prepping for paint and shooting it is WAAAAAAY easier.
Old Jan 15, 2012 | 10:14 AM
Dave145's Avatar
Dave145
That sounds better all together. The trim is what I'm the most worried about because of the little plastic tabs behind it. I heard those break pretty easily.
Old Jan 15, 2012 | 10:24 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The plastic retainers are still available if that's what you're worried about.
X2 on the paint, that's waaaay easier to change.
Old Jan 15, 2012 | 10:38 AM
Dave145's Avatar
Dave145
Sounds good to me. I'll have to see if I can find a cheap bed that's still in one piece.
Old Jan 15, 2012 | 12:44 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Entire bedsides are available from LMC and Certi-Fit.
Josh
Towmanjbo
Nov 27, 2010 02:51 PM
76250_4x4
Oct 24, 2010 08:57 PM
FordF350Baby
Paint & Bodywork
Jul 15, 2008 12:34 PM
turt
Jul 11, 2007 11:56 PM
HardFordCore
13
Sep 30, 2003 05:37 AM
