6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Rail Filter Leak
Old Jan 10, 2012 | 07:28 PM
SandR's Avatar
SandR
Rail Filter Leak
I had a service done about 200 miles ago that included fuel filters. This weekend I drained the rail filter and fuel came out around the handle as well as the drain tube. It is going back to the dealer. Could this be covered under 5/100 warranty if work is needed? As finicky as these fuel systems are is it possible I could have future problems? Since the service the truck mostly sits in the garage because I now have a gas sipper to drive. Thanks
Old Jan 11, 2012 | 09:12 AM
senix's Avatar
senix
It might be covered under the 36/36. Don't know otherwise.
Old Jan 15, 2012 | 07:33 PM
SandR's Avatar
SandR
Update - dealer said o rings around valve handle were bad. They said it happens with the winter blend fuel sometimes. Not sure if it makes sense but a heads up for anybody that has the same problem.
Old Jan 15, 2012 | 08:46 PM
slowmans's Avatar
slowmans
waranteed?
Old Jan 16, 2012 | 07:12 AM
SandR's Avatar
SandR
Not Ford warranty - I am out of 3/36 and not covered under 5/100 acording to dealer.
Old Jan 16, 2012 | 07:02 PM
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
Bio will do same thing.
Old Jan 17, 2012 | 07:36 AM
blackeyed1's Avatar
blackeyed1
I recently had the same problem with my truck. The dealer replaced the whole rail filter assembly. I was just inside my 3/36 warranty.
BTW - I'm not really new here, moved with new e-mail address and couldn't access my account any longer.
Old Jan 21, 2012 | 09:34 PM
Bounds-Electric
FORD USER
Keep drained or o rings stick, then when you drain they rip!
szotty
17
Dec 11, 2011 01:56 AM
bigrigmike
Jan 14, 2011 06:38 PM
99350Ron
Jan 25, 2010 02:28 PM
circledwelding
Apr 15, 2007 01:06 PM
getnbz
Feb 6, 2007 11:31 PM
