Sponsored by: Real Truck
fuel leak help
Old Apr 15, 2007 | 11:22 AM
circledwelding's Avatar
circledwelding
Unhappy fuel leak help
Does anyone have any suggestions on fuel spitting from fuel filter o ring with ignition turned on? didn't do this till a couple of days after changing fuel filter. Cleaned out fuel return line, done good but started again. is there another name for the fuel return line?
Old Apr 15, 2007 | 12:54 PM
riggz's Avatar
riggz
which filter? and what year? is it under warranty?
one of my dept.'s 03 ambulance F350's developed a leak at the filter housing on the engine. it's at the shop now being repaired under warranty.
Old Apr 15, 2007 | 01:06 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you are talking about the diesel 6.0. Filter on frame rail. You re-installed filter cap wrong. Remove it and retighten....make sure it goes ALL THE WAY IN!!!
OH yeah...hopefully, you installed correct filter.
