Wastegate and DP
Old Jan 5, 2012 | 03:55 PM
Superduty ROCKS's Avatar
Superduty ROCKS
Wastegate and DP
Gotta question.
When cold and in stock tune, truck will not go anywhere, no matter what I do to the go pedal. If I change to any other tune, it takes off, but not perfect. As in takes a while to get up to speed.
I just put the DP Tuner in a month ago before it turned cold out. Runs fine in any tune, once warmed up.
Could this be a tuner problem, wastegate, etc?
Its for the truck in my sig.
Thanks for the help guys and gals
Tom
Old Jan 5, 2012 | 04:01 PM
ToMang07's Avatar
ToMang07
When this happens is the exhaust any different sounding?
Old Jan 5, 2012 | 04:04 PM
Superduty ROCKS
Can't tell, because it has no go. Just like it's idling.
Old Jan 5, 2012 | 04:20 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You might give Jody a call, but I know he builds his tunes so they are not full power till the oil is warmed up. You should be able to drive normal though.
Old Jan 5, 2012 | 04:27 PM
Superduty ROCKS
Still browsing FTE.
Could this be an Exhaust Backpressure Valve issue?
Old Jan 5, 2012 | 04:31 PM
ToMang07's Avatar
ToMang07
An EBPV wouldn't totally kill your power... just make it drag azz.
But that is what I am thinking... I would still give Jody a call.
How cold are you talking? What are you using for oil? How old is your fuel filter? No CEL or flashing O/D light?
Old Jan 5, 2012 | 04:38 PM
Superduty ROCKS
[quote=ToMang07;11242149]An EBPV wouldn't totally kill your power... just make it drag azz.
[/quote
48 F today. 26 F this morning. Did this problem in the morning, and 8 hours later after sitting this afternoon.
Rotella 15w40. 150 miles on oil change.
10,000 on fuel filter.
No CEL or flashing OD light.
Bought the truck new and have never had this problem.
Old Jan 5, 2012 | 04:40 PM
miller_feed
Take the chip off the PCM and see if it still does this.
Old Jan 5, 2012 | 04:43 PM
MR5x5's Avatar
MR5x5
If your EBPV is engaging it absolutely will not sound like a normal idle. It will sound like a jet engine with a very noticeable hiss. Also, the EBPV will not effectively "disable" the truck. It will rob a good deal of power to be sure - but it will still "go." Assuming things are working correctly and it is the EBPV, then tapping the break peddle should disengage the EBPV.
Old Jan 5, 2012 | 05:53 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
I would look at the TPS, maybe spray it with some contact cleaner.
Old Jan 5, 2012 | 06:12 PM
Superduty ROCKS
I'll call Jody in the morn, and see what he has to say.
Will report back with any suggestions.
Tom
Old Jan 5, 2012 | 09:26 PM
hedhntr's Avatar
hedhntr
i got stuck on a boat ramp because my exhaust valve got stuck closed. unplug it and see if that changes it
Old Jan 6, 2012 | 08:45 AM
Superduty ROCKS
No problems this morning at 54F.
Waiting on call back from James at DP.
Can anyone PM me Jody's #?
Old Jan 6, 2012 | 09:04 AM
Superduty ROCKS
Ha.
Just got a call from Jody.
He suggested that I don't have to warm up in stock tune.
Just use one of the other tunes. Tunes only at about 30% power till oil temp is warmed up.
Super nice guy to talk with.
I love my DP Tuner!
Pitcrw6
Nov 10, 2012 08:08 AM
Tugly
15
Apr 12, 2012 09:28 AM
Tugly
Apr 3, 2012 07:37 PM
Burke4344
15
Jun 5, 2011 08:18 AM
MAD
Nov 23, 2007 03:06 PM
