Excursion
Old Jan 4, 2012 | 10:47 PM
DennisBauer's Avatar
DennisBauer
Just kinda a simple thing to try that's worked on old cars in the past have someone cycle the key and try pounding on the tank, some times the motor will shake loose, can't hurt too try, same idea as hitting your starter when it has a dead support l spot. And if we could set a time up we should meet up and try to get that thing fired!
Old Jan 5, 2012 | 06:02 AM
prsbrd's Avatar
prsbrd
I am going to try and get it into a garage and work on it. Will let you know. Thanks
Old Jan 5, 2012 | 08:49 AM
LX Sport's Avatar
LX Sport
On the 93 F250 you can ground on of the wires on the test plug and turn the key on and the fuel pump will keep running. Not sure how to make that happen with the ODB2. Also if you have fuel in the tank and its 0 out at night it may take some time for the fuel temp. to get above 32 deg. and the ice to melt.
hogrydr
Feb 16, 2013 06:01 PM
RVA
1997 - 2003 F150
Oct 3, 2012 05:51 PM
james_leland
Aug 11, 2009 09:29 PM
birdmanslopy
1983 - 2012 Ranger & B-Series
Jun 15, 2006 09:30 AM
Jawnnie Darko
Jul 23, 2004 05:57 PM
