fuel pump
Old Aug 11, 2009 | 08:02 PM
james_leland's Avatar
james_leland
fuel pump
I have a 1994 F-250, The truck started to stall out really bad, so I thought it had to with the timing. so I change the cap, rotor, coil, and the TFI. After all that the truck just turned over and over, wouldn't even start. So after getting shocked to death, my guess is its something with the fuel.. I changed the fuel filter, but I can't hear the pump in the tank, so I was looking for the fuse, and it isn't in the fuse box under the dash. I tested all the ones under the hood. So my question is, is it a relay and if it is, where is that located??
Old Aug 11, 2009 | 08:05 PM
Volvo92906's Avatar
Volvo92906
Well, I doubt its tripped but there is (should be) a small black box under the driver dash on the firewall or whatever. Its an inertia switch. Its got a button on it that can trip. It shuts off the fuel pump in case of emergency. Also, I believe the fuel pump is relay run, not fused although I could be wrong.
Old Aug 11, 2009 | 08:13 PM
james_leland
I check that, and it was under the right side of the dash, I re-set it.
Old Aug 11, 2009 | 08:15 PM
Volvo92906's Avatar
Volvo92906
Yeah, some of them are on the right but im not sure how its set up. I got a 150.
Old Aug 11, 2009 | 08:20 PM
james_leland
thanks for the help, I hate to do it. I guess when I get back I will have to bring it in to a mech.
Old Aug 11, 2009 | 08:24 PM
Volvo92906's Avatar
Volvo92906
Giving up so easy? Find out if the relay is working. If the relay works you could just have a bad pump. Is it a single tank? Im assuming you would have tried the other if it was a dual but I thought id ask.
Old Aug 11, 2009 | 08:48 PM
james_leland
No not giving up at all, I don't know where the relay is. its a single tank.
Old Aug 11, 2009 | 08:58 PM
Volvo92906's Avatar
Volvo92906
Umm, maybe its in the engine compartment on the fender side. Haynes says there is a cover you remove to expose the relays and the locations of various ones are marked on the under side of it.
Old Aug 11, 2009 | 09:05 PM
james_leland
checked all of those. and all the fuse are good, check the relays as well. I think when I get back home, I'll just put a new fuel pump in. I looked in the haynes as well, and they don't really show a relay for the fuel pump..
Old Aug 11, 2009 | 09:07 PM
james_leland
I wonder if it isn't that inertia switch, went bad all together??
Old Aug 11, 2009 | 09:13 PM
Conanski's Avatar
Conanski
Fuel pump and EEC relays are on the drivers inner fender. Before replacing the fuel pump check that the relay is being latched when the key is turned on, if it isn't then the computer is likely the problem.
Old Aug 11, 2009 | 09:18 PM
Volvo92906's Avatar
Volvo92906
Conanski knows his stuff. Listen to him.
Old Aug 11, 2009 | 09:21 PM
james_leland
here is how the problem started, the truck ran fine till it got up to temp. Then it would stall, I thought it was the egr vavle cause that is what happened to my 89. changed that. still had same problem. Thought it had to be a timing problem change it all but the dist. Get plenty of spark, truck turns over great just won't fire..
Old Aug 11, 2009 | 09:25 PM
Volvo92906's Avatar
Volvo92906
?Fuel?, <strike>spark</strike>, <strike>air</strike>, ?computer?. Thats basic function.
Old Aug 11, 2009 | 09:29 PM
james_leland
you know it, trust me I can use all the advice I can get.
Monster-4
Modular V10 (6.8l)
Nov 4, 2013 08:17 AM
cipcom
1997 - 2003 F150
Oct 1, 2013 07:34 PM
shok47
1983 - 2012 Ranger & B-Series
Nov 10, 2012 09:36 AM
MrJames159
Nov 11, 2010 08:15 PM
slammindeuce
Dec 17, 2001 11:21 AM
