Project Midnite UPDATED
Old Aug 12, 2012 | 05:44 AM
  #241
KingBigJoe's Avatar
KingBigJoe
Nice work, Midnite. Subscribed !
Old Aug 12, 2012 | 06:47 AM
  #242
norfolknova's Avatar
norfolknova
Have you thought of installing hard tie down points onto your flatbed. The reason I mention this you said you are going to carry your RZR an preinastalling tiedown points on the corners would make it easier to secure the RZR to the truck
Matt
Old Aug 17, 2012 | 09:10 PM
  #243
Midnite1987's Avatar
Midnite1987
got my decals today! thank norfolk they look great!
if you look close there are 3 tie down points down each side but i plan on building short sides and adding more tie down points at the same time.
Old Aug 23, 2012 | 09:36 PM
  #244
1991F35075L's Avatar
1991F35075L
I am not really into red lights for an instrument cluster just mess with my eyes too much. But I like what you did with your truck looks like a lot work went into her!
Old Aug 23, 2012 | 11:12 PM
  #245
FordYoungGun35's Avatar
FordYoungGun35
Sorry I'm a little late but how did you get the lights red? I've got blue lights all over mine so how can I get them blue?
Old Aug 23, 2012 | 11:21 PM
  #246
Midnite1987
First thing is to take a pic o where all the needles sid when idling in park with a warmed up motor. For reference later. You need to remove the cluster and take the front plastic off. Carefully pop the needles off the gauges and peel the cover with the numbers off. On the back side you will see white over the numbers. There's the green under the white. Take a bunch of q-tips and rubbing alcohol and work at it till the green is gone. (hold up to the light frequently to see what green is left and finish removing. The odometer had a green film on the back pf the little display as well. Now is the time to swap all the bulbs to color pf choice. Then put it back together without the front plastic cover and put back in dash. Start truck and get to operating temp then place the needles back on in the same position ad the picture you took before. Aparently there's a way to to the speedometer that easier but I drove to 60km/h as per my gps and stuck the needle on at 60 then varified at different speeds it's right. Then re assemble the rest.
Old Aug 26, 2012 | 04:19 PM
  #247
FordYoungGun35
Will someone tell me how to take off the needles before I break something!!!
Old Aug 26, 2012 | 04:24 PM
  #248
Puddy's Avatar
Puddy
I used tweezers, slipped them on both sides and pulled up, take pics before removing them so u know where to put them back..... Very crucial, and don't lay the gauges face down or u screw up the speedometer
Old Aug 26, 2012 | 04:35 PM
  #249
FordYoungGun35
I took pics I'm just scared that I'll snap the needles and mess it up
Old Aug 26, 2012 | 05:42 PM
  #250
FordYoungGun35
In the first post about the gauges you said use alcohol to scrub off the green will peroxide work?
Old Aug 26, 2012 | 05:51 PM
  #251
FordYoungGun35
Nvm I got alcohol
Old Aug 26, 2012 | 09:32 PM
  #252
bigredk8's Avatar
bigredk8
Originally Posted by Midnite1987
but add a "pre runner" light bar piece to the top like this one.
Any one know where I could get one of these pre runner bars?
Old Aug 26, 2012 | 09:36 PM
  #253
FordYoungGun35
Anyone got a pic of what the gauges look like with the green film off with just stock bulbs behind em?
Old Aug 26, 2012 | 09:51 PM
  #254
minnesotafisherman's Avatar
minnesotafisherman
I'm wondering too.. That looks awesome.
Old Aug 26, 2012 | 09:57 PM
  #255
Midnite1987
Realized I want a bigger truck...
Went to haul the rzr an camping gear on the deck and was 1/4" off the bump stops. So I borrowed the 14' elcolsed trailer from work and it went better but it had a hard time with it on a couple of the hills and I was down to 8mpg on the hwy pulling the trailer with my rzr in it...
So I'm puting it up for sale so I can get a 3/4 or 1 ton. I'd prefer a 95-97 f250/350 Crew cab, long box 4x4 with either the 460 or diesel.
But those are HARD to find up here so I might end up looking for a 2003 and older powerstroke. I don't want the 6.0l
some pics from the weekend.
started out the trip like this...
shortly after leaving home i realized i needed to go get the trailer...
no issues on the way other then the truck being undersized and the 8MPG... lol
getting ready to load it to go home. all muddy. it ran perfectly except the tree that came through the floor board lol
