Project Midnite UPDATED
Old Jun 2, 2012 | 09:32 PM
  #166
OleStephens's Avatar
OleStephens
Trailering
Check some junkyards. We got some for my dad's F250 off of a rolled truck in a junkyard.
Old Jun 2, 2012 | 09:41 PM
  #167
Midnite1987's Avatar
Midnite1987
Oh I've been looking. I can't even find any use ones online
Old Jun 2, 2012 | 09:56 PM
  #168
Midnite1987
Ok I just can't win... The 6k960 belt is too short barely and the next size up is a 6k968 which I can JUST slide on by hand with out moving the tensioner... Looks like I'll be shimming the alternator out with a few washers to take up the slack....
Old Jun 2, 2012 | 11:37 PM
  #169
Midnite1987
Well I ended up shimming the alternator with a 1/2" nut under each bolt and sofar so good.
I seem to have a ticking sound you can hear in the first video below anyone know how I might be able to get rid of the ticking?
<iframe width="560" height="315" src="http://www.youtube.com/embed/8cMP3RaZMkQ" frameborder="0" allowfullscreen></iframe>
And another clip of my exhaust now
<iframe width="560" height="315" src="http://www.youtube.com/embed/ilniiIyn-Ac" frameborder="0" allowfullscreen></iframe>
Old Jun 2, 2012 | 11:53 PM
  #170
minnesotafisherman's Avatar
minnesotafisherman
I remember having a ticking noise a while back after having the timing chain replaced, and it turned out to be the EGR tube. Had a hole in it. Shop replaced it for me free of charge and voila, no more ticking!
And what does removing the smog stuff and bypassing the idler pulley benefit?
Old Jun 3, 2012 | 12:20 AM
  #171
Midnite1987
dont know if removing the smog stuff will bennifit anything more then less stuff in the engine bay.... lol the hoses were tight between the alternator and the inner fender and the block was hittinf the firewall on the back side. when i pulled the bracket to remove the broken tensioner bolt i had to cut a hose clamp on the air piping and just decided to remove it all together.
now bypassing the idler gave me the best wrap of the belt on the other pulleys, with still using the idler the tensioner didnt do much. i could have gotten a idler for the air pump location but im cheap lol.
Old Jun 3, 2012 | 12:37 AM
  #172
minnesotafisherman
Oh alright. Thanks for clearing that up haha.
Good luck finding the cause of that ticking noise.
Old Jun 3, 2012 | 01:44 AM
  #173
XLT89F350cc's Avatar
XLT89F350cc
i say check the 3/8' pipe plug for leaks, doesnt look like theres any other lines to check.
Old Jun 3, 2012 | 01:52 AM
  #174
Midnite1987
Yeah I'll check that one tomorrow if that is it not sure how else to seal it
Old Jun 3, 2012 | 01:59 AM
  #175
XLT89F350cc
my dad (88dually) crimped an brazed the end of his
Old Jun 3, 2012 | 02:01 AM
  #176
Midnite1987
I tried to pinch the piece I cut off and that crap is HARD lol
Old Jun 3, 2012 | 02:09 AM
  #177
Midnite1987
I'm thinking possibly some Jb weld around the plug if that is where it's comming from. I'll take a closer look tomorrow
Old Jun 3, 2012 | 02:20 AM
  #178
XLT89F350cc
jb welds a good idea. put it on the threads as you re-screw it
Old Jun 4, 2012 | 11:13 PM
  #179
Midnite1987
well went out to look at that pipe and the ticking is gone... hmmm...
on another note i got a different belt yet again . i ended up with a 94.5" belt and even found a gatorback one for $18 and i changed the routing on it again back to the stock routing using the idler just without the air pump in place. and back up and running again with no squealing
and got a couple small loads of dirt today so of course had to play in it sorry bout the quality
<iframe width="420" height="315" src="http://www.youtube.com/embed/ntSLfDVekWk" frameborder="0" allowfullscreen></iframe>
Old Jun 5, 2012 | 08:08 AM
  #180
Grubbworm's Avatar
Grubbworm
Those Goodyear Gatorback's are one of the best belts on the market. If available, that is the only belt that I use on any of my vehicles. I don't know if it is still available or not, but they used to be covered by a lifetime warranty.
