stupid question...
Old Dec 29, 2011 | 10:47 PM
matowns21's Avatar
matowns21
Originally Posted by oldbird1965
x2, buy a oil bypass system and don't worry about it.
What exactly is a oil bypass system? Sorry very new to diesel trucks and learning new things everyday.
Old Dec 30, 2011 | 07:17 AM
CampSpringsJohn's Avatar
CampSpringsJohn
An oil bypass system is designed to filter out a lot more contaminants in the oil so you don't need to change the oil near as ofter. It is a separate filtration system than what your truck currently has. You usually run synthetic oil, and the bypass filter system is a non-pressurized system if I'm not mistaken. You take oil samples periodically, and change the filters at certain intervals. Oil changes are usually done only when a sample says it's necessary.
Old Dec 30, 2011 | 08:08 AM
fordpride's Avatar
fordpride
I'm sure you can find it cheaper
AMSOIL BMK-26 Ford 7.3L PowerStroke Oil Bypass Unit
Old Dec 30, 2011 | 08:33 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by madpogue
Call me a dork, but I siphon out the HPOP res on an oil change. Yeah, I know it circulates with the lube oil, but that's just it; that's at least a quart of oil, and leaving it in would be like pouring a quart of old oil back into the crankcase following an oil change. And yeah, I know, that still leaves all the oil in the rails and such, but IMHO, the less old oil mixed in with the new, the better. (Remember the olden days when they recommended an oil filter change only every _other_ oil change? I always thought that was .) I just use one of those cheapo five-dollar Harbor Freight hand pump siphons; takes about two minutes.
But otherwise, yeah, that Bill guy is a hoot. Pro-long on your corn flakes?....
So NOW we have two dork: Bill (in the video) and madpoque LOL
Old Dec 30, 2011 | 09:27 AM
oldbird1965's Avatar
oldbird1965
Or, FS-2500 :: Ford F-250 thru F-550 7.3L
altonlee
Apr 13, 2016 10:27 AM
wheelerg
Feb 2, 2014 12:14 PM
05 f250 6 inch lift
Oct 31, 2012 06:26 AM
knuss3807
May 13, 2012 07:25 PM
Cobratodd
Mar 9, 2006 11:42 PM
