I have a 97 f250 I replaced the fuel pump a couple weeks ago and it ran fine. Now if you let it set a couple hours it will run about 2 minutes then go dead. Checked it today and it isn't pumping fuel again. Is it likely to get a bad pump or do I have something else going on?
I don't know about both tanks as I rarely use the rear tank and it has little to no fuel in it. If it was the pick up would it work at all? Mine will crank and idle ok for about 2 minutes then shut down like you turned the key off. It won't start back up for a couple of hours.
yeah, I spose not. Are you sure it is fuel related? iIs your bowl empty when it shuts off? Actualy, I am not sure if the bowl goes dry when the pump stops pumping.
I helped pull the bed on a ranger. Took no time. 6(?) bed bolts, 1 wire harness and 3(?) screws at the filler neck. Can you shoot compressed air back through the tube to avoid pullen the bed/tank?
