fuel pump problem
Old Dec 28, 2011 | 02:38 PM
matowns21's Avatar
matowns21
fuel pump problem
I have a 97 f250 I replaced the fuel pump a couple weeks ago and it ran fine. Now if you let it set a couple hours it will run about 2 minutes then go dead. Checked it today and it isn't pumping fuel again. Is it likely to get a bad pump or do I have something else going on?
Old Dec 28, 2011 | 03:28 PM
fordpride's Avatar
fordpride
You could have got a bad pump
Old Dec 28, 2011 | 04:28 PM
Copedawg's Avatar
Copedawg
does it do it on both tanks? Could it be a bad pick tube?
Old Dec 29, 2011 | 07:15 AM
matowns21's Avatar
matowns21
I don't know about both tanks as I rarely use the rear tank and it has little to no fuel in it. If it was the pick up would it work at all? Mine will crank and idle ok for about 2 minutes then shut down like you turned the key off. It won't start back up for a couple of hours.
Old Dec 29, 2011 | 08:08 AM
Copedawg's Avatar
Copedawg
yeah, I spose not. Are you sure it is fuel related? iIs your bowl empty when it shuts off? Actualy, I am not sure if the bowl goes dry when the pump stops pumping.
Old Dec 29, 2011 | 08:58 AM
matowns21's Avatar
matowns21
Bowl isn't empty just doesn't try to fill anymore with the filter out.
Old Dec 29, 2011 | 09:22 AM
fordpride's Avatar
fordpride
Drain the bowl put the filter and cap back on and crank it to see if the bowl fills up
Old Dec 29, 2011 | 09:35 AM
matowns21's Avatar
matowns21
Ok. I will try that tomorrow. I talked to ford service they said pull the tanks and check for debris clogging a sock? How hard is this to do?
Old Dec 29, 2011 | 09:58 AM
fordpride's Avatar
fordpride
It's easier to pull the bed
Old Dec 29, 2011 | 10:07 AM
matowns21's Avatar
matowns21
Ok. I don't have a cherry picker so this is going to be a job... I think.
Old Dec 29, 2011 | 10:32 AM
fordpride's Avatar
fordpride
You and two buddies can lift the bed
Old Dec 29, 2011 | 10:35 AM
Copedawg's Avatar
Copedawg
I helped pull the bed on a ranger. Took no time. 6(?) bed bolts, 1 wire harness and 3(?) screws at the filler neck. Can you shoot compressed air back through the tube to avoid pullen the bed/tank?
Old Dec 29, 2011 | 10:37 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Have you cleaned the fuel bowl screen?
Old Dec 29, 2011 | 10:43 AM
matowns21's Avatar
matowns21
Fuel bowl screen?
Old Dec 29, 2011 | 10:45 AM
matowns21's Avatar
matowns21
I would be afraid to do the compressed air.. my luck isn't very good. I would probably break something lol
