fuel pump problem
Old Dec 29, 2011 | 11:06 AM
Copedawg's Avatar
Copedawg
Originally Posted by RÖENTGEEP
Have you cleaned the fuel bowl screen?
LOL, yeah. I couldn't see the forrest b/c all the trees were in the way. "FPR screen" did you rebuild the bowl when you pulled the pump last?
The screen is between the fuel cannister and the regulator. 2each 10mm bolts and a hose clamp will let you in.
Old Dec 29, 2011 | 11:09 AM
Copedawg's Avatar
Copedawg
If it was a "sock" you would not have the symptoms while pulling from the other tank. I would go with the screen. Take it all the way out and clean it up real good. You will be surprised how dirty that little fugger can get
Old Dec 29, 2011 | 11:15 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Thank you Ian. When you go for the screen be careful dont loose the o-ring between the FPR anf bowl and the little plastic ball in the back of the plastic part which retains the screen, its between this plastic part and the FPR. OK?
Old Dec 29, 2011 | 11:24 AM
matowns21's Avatar
matowns21
No I didn't rebuild it. I will try the screen cleaning. I did clean the bowl well. It had a bunch of junk in it. If it was the screen it should still pump to the bowl right?
Old Dec 29, 2011 | 01:28 PM
matowns21's Avatar
matowns21
I rarely ever use the rear tank difficult to fill so I don't know if it does it on that tank. Do you think it would be worth my time pulling the bed off to check the tanks?
Old Dec 29, 2011 | 02:15 PM
Copedawg's Avatar
Copedawg
I would do the screen before anything, like ROENTGEEP suggested, (those are classic symptoms) . I would even take the time and get a O-ring kit from Jim and rebuild the canister and regulator just for peace in the mind when the weather breaks. I would pull the bed after you have exhausted all other bases. but that's just me. Let us know what you find out with the screen (should take 10-15 minutes). Where do you live? Where is your signature?
Old Dec 29, 2011 | 02:17 PM
matowns21's Avatar
matowns21
I live in west TN, haven't figured out the signature on my phone yet... Who is Jim?
Old Dec 29, 2011 | 02:26 PM
Copedawg's Avatar
Copedawg
signature....upper left "CP User" button....then look on the left for "edit signature" on the left.
DZL JIM is one of the sponsors here. He will give you a link for the rebuild kit when he comes along.
You gonna try the screen today?
Old Dec 29, 2011 | 02:52 PM
matowns21's Avatar
matowns21
Working today. Screen, oil cooler, and new fuel pump Sunday.
Old Dec 29, 2011 | 03:14 PM
Copedawg's Avatar
Copedawg
The "Day of Rest"? On the 1st to boot? Enjoy! and keep us posted!
Old Dec 29, 2011 | 03:27 PM
matowns21's Avatar
matowns21
Yea with this truck so far it hasn't had a rest from malfunction....I hope this will change soon or it might be up for sale.
Old Dec 29, 2011 | 03:35 PM
Copedawg's Avatar
Copedawg
keep your chin up and roll with it, Brother! We will walk you through it...every step of the way, if need be.
Old Dec 29, 2011 | 03:43 PM
  #28
matowns21's Avatar
matowns21
I appreciate that... If I can get the fuel issue and oil leak then maybe... Only other thing I don't like is it smokes like a freight train after it sets 8-10 hours cold or hot weather. I have talked to mechanic after mechanic and they don't know. One says injectors one says air in the fuel one says it normal... Diesels are definitely not like a gasser.
Old Dec 29, 2011 | 03:47 PM
  #29
Copedawg's Avatar
Copedawg
Is your oil filter dark/black? If so you may wanna replace the Injector O-rings too. How many miles do you have? Is your truck a daily driver? You have something else to drive?
Old Dec 29, 2011 | 03:55 PM
  #30
matowns21's Avatar
matowns21
Yea I have something else to drive... Shoot I have to can't keep this thing running long enough to be a primary...lol I just replaced 4 injectors... I would think the guy I paid $1200 would have checked all of the orings. The truck has 240,000 ish miles the oil filter? It is fram...
