fuel pump problem
Old Dec 29, 2011 | 04:02 PM
  #31
Copedawg's Avatar
Copedawg
I'm sorry, what color is the fuel filter.....With a basic tool set and this site, you will never have to PAY ANYBODY to look at your vehicle again!
Old Dec 29, 2011 | 04:11 PM
  #32
matowns21's Avatar
matowns21
I was wondering about this. I replaced the fuel pump and filter both the same day. 12/09/11 fuel filter now is dark grey and has had less ruM a full tank run on it.
Old Dec 29, 2011 | 04:17 PM
  #33
Copedawg's Avatar
Copedawg
If your filter is dark.... is an indication that your injector O-rings could be worn.
Old Dec 29, 2011 | 04:20 PM
  #34
matowns21's Avatar
matowns21
How is this job done? If it is would that improve mpg? The injector job seemed too much for me to handle. That's why I hired a "pro" lmao
Old Dec 29, 2011 | 04:24 PM
  #35
Copedawg's Avatar
Copedawg
I thought the same when I 1st came around....but these guys here will walk you right through it in almost real time! YOU CAN DO IT!
Old Dec 29, 2011 | 04:29 PM
  #36
matowns21's Avatar
matowns21
So how do I know if this needs to be done?
Old Dec 29, 2011 | 04:30 PM
  #37
Copedawg's Avatar
Copedawg
Well, lets do the screen and get it running first and go from there
Old Dec 29, 2011 | 04:31 PM
  #38
matowns21's Avatar
matowns21
Will update Sunday afternoon. Thanks again.
Old Dec 29, 2011 | 04:51 PM
  #39
Copedawg's Avatar
Copedawg
We'll be here!
Old Jan 1, 2012 | 01:35 PM
  #40
matowns21's Avatar
matowns21
Ok pulled the fuel bowl off to get to the pump and the fuel in it smells like gasoline... What do I need to do at this point?
Old Jan 1, 2012 | 03:19 PM
  #41
fordpride's Avatar
fordpride
If you have gas in you system your gonna have to fluse the whe system and empty the tanks and fill with good diesel
I would suck the tanks dry then blow the fuel lines back to the tanks ( feed and return) then suck the rest of the fuel out and fill with clean fuel
Old Jan 1, 2012 | 05:14 PM
  #42
matowns21's Avatar
matowns21
False alarm. I had my wife smell of it and she said diesel... Dang allergies. I got the new pump on and cleaned the fpr screen and wow what a difference. I don't know if I just got a bad pump or what but this thing has the best throttle response that is has ever had and good clean idle. It is still blowing white smoke but not nearly as much. We will see if this fixes it... Still got to do the oil cooler orings and gaskets but think I will wait to make sure its going to run first... Happy new year everyone!
Old Jan 1, 2012 | 05:38 PM
  #43
Action4478's Avatar
Action4478
Glad you got it going ...
Sorry to say , it wasn't the screen ... that is the fuel return line ...
You may still want to verify the tank pickups ...
Old Jan 2, 2012 | 09:51 AM
  #44
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Why do yo say that? Maybe was a bad fuel pump IDK.
HAPPY NEW YEAR TO ALL.
Old Jan 2, 2012 | 07:11 PM
  #45
matowns21's Avatar
matowns21
Ok its about 30* outside the truck has been sitting all day and I cranked it when I got home. It fired right up but went dead twice before warm cranked right back then almost went dead again but caught itself. It seems to be running fine now. My truck doesn't have a plug so it has set in 28* wind chills all day. Are they that cold collared or do I have something wrong? It is around 6-700 rpm but when it about went dead it dropped around 300 then caught itself. I have noticed every once in a while you hear something sounds like air blowing from in behind the radio but lower and the truck choked down. Any help is greatly appreciated.
