Starter Advice
Old Dec 26, 2011 | 09:14 PM
njkite51's Avatar
njkite51
Starter Advice
Happy holidays everyone! My truck has been more and more difficult to start the past 2 months and i believe it is the starter. I put a load test on the batteries and when turning the key voltage dropped from about 13.2 to 8v. I did the same thing on an identical truck and voltage only dropped to 11.5v So this leads me to believe its time to replace the starter. She is an 04 with 102xxx on her.
My question is to go with the starter from the local advanced auto parts for $210 plus core, or go the ebay route. I found this one which has the same specs but is a lot more wallet friendly. Any advice would be appreciated. Excursion Diesel Starter 6.0 Liter 03 04 05 New Ford | eBay
Old Dec 26, 2011 | 09:17 PM
cheezit's Avatar
cheezit
have you tested the batteries yet? dieing cells will casue the same issue. droping below 9.5v most of these trucks wont start. also its very bad on the ficm's
Old Dec 26, 2011 | 09:19 PM
bismic's Avatar
bismic
nevermind - slow fingers tonight!
Old Dec 26, 2011 | 09:34 PM
w_huisman's Avatar
w_huisman
Sounds more like it needs batteries than a starter, but I have been wrong before.
Old Dec 27, 2011 | 12:06 AM
njkite51's Avatar
njkite51
the batteries were replaced less then a year ago and load test like they are still new. That is why I believe it is the starter?
Old Dec 27, 2011 | 12:08 AM
dukie1877's Avatar
dukie1877
+1 on the batteries you have some heavy hitters here sayin the same thing. Might save yourself some cash. How old are the batteries? Although I have bought new batteries bad so it really dont matter much other than if they are really old it is most likely the cause or atleast could be part of the issue.
Old Dec 27, 2011 | 06:19 AM
npccpartsman's Avatar
npccpartsman
++1 on the batteries. They should never drop to 8 volts and age has nothing to do with it. Make sure they are load tested separately by disconnecting one of the ground cables.
If you are absolutely determined to replace the starter then go to NAPA and get one. It cranks faster than the stock starter and the solenoid wiring attachments are MUCH stronger than stock. I've had one for 5+ years now and have had excellent luck with it.
Old Dec 27, 2011 | 06:51 AM
bismic's Avatar
bismic
How many amps on the load test?
Old Dec 27, 2011 | 09:28 AM
njkite51's Avatar
njkite51
I will re test the batteries today and post results before proceeding with the starter. Thank you for all the help thus far
Old Dec 27, 2011 | 10:28 AM
69cj's Avatar
69cj
Remember to make sure that they are totally isolated from each other. Very important.
Ford79
May 26, 2011 07:48 PM
MissIndependent
19
Nov 30, 2009 09:41 PM
IDPisan
Oct 6, 2009 01:43 PM
jporter
Nov 6, 2004 09:23 PM
JD2DAWN
Mar 8, 2004 03:32 PM
