injection timing
Old Dec 24, 2011 | 04:54 PM
Deereguy90's Avatar
Deereguy90
injection timing
i am sorry i have not been on for a few i have been working alot
the last time i was on i needed a new injection pump so i got one. the pump that was on the truck i think was off a 7.3 and i got one for a 6.9 i dont no if that maters and if it does i would like to know please.
now i have not put the new pump on but a would like to know what stroke the injection needs to be on and how to set it all up so that i can have my truck back it has been a few mounths
if anyone could help me with this i would be happy think you
and happy xmas to all
Old Dec 24, 2011 | 05:12 PM
charleswood6969's Avatar
charleswood6969
Not enough info provided....the 6.9 N/A and the 7.3 N/A should use the same pump. Not sure if the 6.9 N/A will transverse to the 7.3 turbo though.
Easy enough. Three exterior nuts holding the flange to the mounting on the drive cover. Then, three 12-point (1/4 or 3/16th's, if I remember right) under the small round cover on the front of the drive. Those hold it to the gear. The gear and the FI pump mesh together with a keyway, so, as long as they slide together, it is timed.
Take off all the fuel lines at the injectors. Leave the fuel lines that go to the injectors on the pump. Take off the input fitting on the end of the FI pump (It needs to slide back and it hits the intake manifold) Take off the three nuts (The one closest to the passenger side is a b***h. Grinding a 9/16th wrench thinner on both the box and the open end seem to help. Three bolts under the front cover. Remove the pump. Swap the fuel injector lines from the old to the new. Reverse the process.
Old Dec 24, 2011 | 05:21 PM
charleswood6969
Oh, and there should be a small mark on your pump, and a small mark on the drive flange. That is where the 'static time' mark is. It gets you in the ballpark of where it should end up as far as being 8.5 degree before TDC as far as the advance timing is concerned.
Old Dec 24, 2011 | 05:49 PM
jb10725's Avatar
jb10725
I just changed the injector pump on mine, these bolts he's talking about here are a 5/16" 12 point bolt head. International specs say to tighten these to 25ft-lbs. when installing a pump.
Old Dec 24, 2011 | 05:58 PM
Deereguy90's Avatar
Deereguy90
Thinks for all the info but the problem i have is the timing from the cam to the injection pump is what i am having trouble with.
Old Dec 24, 2011 | 06:22 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
sounds like you incorrectly pulled the ip.oops!
(don't feel bad.it's mistakenly pulled very often,sadly.)
this will fix you up:
"Talk about Timing!!"
how to correctly remove and instal the ip can be found here,to avoid such trouble next time:
https://www.ford-trucks.com/forums/1...p-ratings.html
Old Dec 26, 2011 | 02:15 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Worth trying
Deere,
Give this post a read through.
https://www.ford-trucks.com/forums/1...plumbers+putty
Good luck,
Mac.
twfs
Apr 26, 2009 01:36 PM
Red Sled
Sep 5, 2008 05:55 PM
DirtStripHero
Jul 13, 2008 06:18 PM
PeteyF-250
Mar 2, 2006 12:08 PM
Mopar_2
Jul 25, 2003 11:01 AM
