Please help! I'm going Crazy.
Old Jul 11, 2008 | 06:04 PM
DirtStripHero's Avatar
DirtStripHero
On the truck in my signature I was attempting to turn down the fuel injection pump on the top of the engine. In the process I stripped the head off one of the bolts that holds the plate on where you adjust it. Normally I would just drill out a broken bolt but I cannot fit a drill in such a tight space. And I tried to take the pump off but it is not wanting to come off either. Does anyone have any suggestions? On either getting the bolt out or taking the pump off. THanks
Old Jul 11, 2008 | 07:00 PM
LilDuke's Avatar
LilDuke
Use some vise grips on it, then replace with new bolts.
Old Jul 11, 2008 | 07:05 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
To take the pump off, Undo all the injection lines at the injectors first along with the supply fuel line at the back ect. Then undo the 3 bolts around the pump holing it to the cover. Then remove the oil filler neck on the front of where the injection pump mounts. When you remove the cover, you will see 3 little bolts that hold the injection pump to the gear. undo those bolts and it should slide back and come right out. I do not know the manufactures way but this is somewhat How i take them off. I usually leave all 8 injction lines attached to the IP so the keep them all organized. May have to work some to get it out but it should come. Anyway, thats on a 7.3 but your 6.9 should not be very much different. Your probably just getting hung up on the bolts that hold the Drive gear to the injectin pump. Well, Good luck.
Old Jul 11, 2008 | 07:31 PM
David85's Avatar
David85
What you just described is the text book way to remove the injector pump on the 6.9 or 7.3 IDI. Only thing I would add is the rear of the pump has to tilt up slightly after it is pulled out of the drive gear housing in order to get it out of its pocket on the top of the engine.
Old Jul 11, 2008 | 08:17 PM
S.P.'s Avatar
S.P.
Are one of the bolts hidden??? I seem to have read that some ware....is that what you mean??? Ive never done the job myself...
Old Jul 11, 2008 | 10:58 PM
FORD MEGA CAB!!!
There will be 3 bolts holding the pump case to the housing. the 2 bolts are the same as the top bolt but are somewhat hidden. you will have a bolt on the top and 2 bolts 1 on each lower side of the pump. I have the specal S shaped wrench that makes it easier to remove but I have taken them off with just a regualr endwrench. I had to use both ends and could only make the bolt turn a few degrees before switching the wrench over and end by end. Took me 5 minuts of turning just to get it out. how many bolts did you take out of the pump holding it to the engine?
David, As for being correct on how to pull the pump, I had no Idea I was correct. Never seen a book for it.
Old Jul 12, 2008 | 09:04 PM
DirtStripHero
Thanks guys. I tried to take the front cover off by pulling the 4 bolts out. I hadnt taken the oil fill neck off yet. but I will try that tomorrow.
Old Jul 12, 2008 | 09:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My post from last night is not here, did you lift the IP drive gear cover up after you removed the 4 bolts holding it down?
Old Jul 12, 2008 | 10:56 PM
FORD MEGA CAB!!!
I wouldn't remove the complete top gear cover assembly, Just the plate that is on the front of it that covers the access hole to get the screws out, which on yours should be the oil fill, if not it will just have a small plate covering it, either one will have 2 bolts. Taking off the complete top cover will require you keep the gear in time and is not required to be pulled to remove the pump..
Old Jul 13, 2008 | 11:58 AM
DirtStripHero
Ya I already messed up lifted that cover off a little bit. I didn't take it completely off, but i picked it up and forward a little. I think I just screwed up big time didn't I?
Old Jul 13, 2008 | 01:48 PM
Dave Sponaugle
If the timing gears were seperated, your IP may not be in time with the rest of the engine.
Old Jul 13, 2008 | 06:18 PM
DirtStripHero
I dont know if they were or not. I am assuming that I will have to start the engine to see if that is the case? I have been working on other projects so I didnt get to work on this truck today.
bryan_johnson
18
Mar 3, 2019 09:13 AM
arctic_driver
Mar 22, 2015 04:38 PM
mdredneck
Dec 22, 2013 09:36 PM
beal460
Oct 2, 2006 08:16 PM
BROKEN88F150
Aug 17, 2005 10:01 AM
