wipers wont work?
Old Dec 24, 2011 | 05:08 AM
XTfx4's Avatar
XTfx4
wipers wont work?
hi everyone , wiper woes? 1979 F350 wiper delay box just clicks when turned on , no motor noise.... just got new switch and delay box because the old one just buzzed, but while messing with the old switch i had gotten the wipers motor to run when i held the **** in just the right place.... so i just figured i needed a new switch ... but nothing... just clicking seems to be in rhythem of what the delay would be ? any ideas or things to check ? going to tear the dash apart today and look around ? could the motor be bad even though i had it working for a bit ?? thanks for any help..
Old Dec 24, 2011 | 03:45 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check and make sure the switch is grounded, the new switch should have a ground pig tail that needs to be connected to a good ground. If it is then most likely it's the motor that's bad. Seeing that you hear a "clicking", that would lead me to believe that more than likely it's motor.
1979camperspecial
Nov 30, 2013 01:31 PM
Tony_C
Sep 10, 2011 09:17 AM
bishopgeer
Sep 12, 2009 12:28 PM
Samsonitesamsonite
Jan 16, 2004 12:49 AM
erk69
May 14, 2003 08:21 PM
