Sponsored by: Auxito
Odd Clunk from Drivetrain
Old Dec 23, 2011 | 08:37 PM
mcdev's Avatar
mcdev
Good evening guys and Happy Holidays.
In the past two weeks my truck has started making an odd clunk sound from the drive train. It occurs when I reverse, shift into drive and proceed. Once I stop for the first time after the shifting it clunks. Any ideas on what is causing this and what the fix might be?
Also, how much can you overfill an automatic transmission before you can cause problems?
The truck is a 2000 F150, 5.4 liter 4x4. 229,000 miles.
Thanks for your help guys.
Barry
Old Dec 23, 2011 | 08:47 PM
70-360fe's Avatar
70-360fe
Barry
Sounds like j joints are going out on the drive shaft. Get under the truck and see if you can move the drive shaft in a circular motion, if it movies j joints need to be replaced. Don't over fill the tranny, period.
Old Dec 24, 2011 | 01:25 PM
mcdev's Avatar
mcdev
Thanks. I will check out the drive shaft this afternoon.
I figured as much about the transmission fluid. I have a knucklehead buddy who insisted that overfilling wasn't a big deal.
Old Dec 24, 2011 | 04:34 PM
steve(ill)'s Avatar
steve(ill)
the older trucks are known to wear the splines on the drive shaft slip joints. When you change direction you can get a shift in the wear area on the splines and get a "clunk". Check the U- joints, but if it only happens "once" then it might be the splines. YOu can take it off and grease the splines and that can help. Some greases are better than others at absorbing shocks.
Old Dec 24, 2011 | 06:41 PM
mcdev's Avatar
mcdev
Thanks Steve. Any suggestions as to which grease?
Old Dec 25, 2011 | 07:31 PM
steve(ill)'s Avatar
steve(ill)
I just used regular chassie grease and worked o.k., some of the guys have used it and the clunkc comes back in 6 months. I have heard of using a moly based grease like they use on bulldozer blade sockets.. some are trying that.
Old Dec 26, 2011 | 08:41 AM
Scalemandave's Avatar
Scalemandave
Check the TSB's at the top of the page. I think there's one for this.
Parcher01
1997 - 2003 F150
Mar 16, 2009 03:44 PM
lablue96
May 26, 2008 12:53 PM
clgreer
18
Jan 28, 2008 10:20 AM
DustinDLamb
Aug 9, 2006 11:31 PM
geraldo14
Sep 25, 2005 09:19 PM
