1978 - 1996 Big Bronco
Different Radius Arms
Old Dec 15, 2011 | 09:47 PM
Captbs32's Avatar
Captbs32
I have put a six inch lift on my Bronco with 35s and I have seriously been considering buying the Long arm kit from JBG. Quite expensive thou. Just going to get some feelers on how they are? If anyone has done them of course. Duh they would look good but for that money I want functionality. Which I think they will.
Old Dec 16, 2011 | 02:33 PM
ExtrmZ's Avatar
ExtrmZ
I did it on my six inch kit. I love them. the extra travel is amazing. It even rides nicer on the road as well
Old Dec 16, 2011 | 04:16 PM
Captbs32's Avatar
Captbs32
did you use the stock radius arm brakets? I already have the lift on the truck. And they are saying the arms themselves will work but I must have the stock radius arm brackets.
Old Dec 17, 2011 | 04:01 PM
Edgethis's Avatar
Edgethis
I believe the kit comes with new brackets:
Front Bracket Kit With Extended Radius Arms
If this ^^ is the kit you are looking at. I would assume, as when you buy the bracket kit without the arms, it shows the radius arm brackets. You could always give them a call and ask for sure.
Front Bracket Kit (4" or 6" Lift)
Old Dec 17, 2011 | 06:26 PM
ExtrmZ's Avatar
ExtrmZ
yes the kit had different brackets because the frame has a different contour further back.
Old Dec 17, 2011 | 08:48 PM
Captbs32's Avatar
Captbs32
Ya I got up with them and they said the arms themselves would work with my kit now if I had the stock radius arm brackets. That doesnt make much sense to me. I thought the other bracket are totally different.
Old Dec 21, 2011 | 11:06 AM
Kemicalburns's Avatar
Kemicalburns
has nothing to do with the frame further back.
if you have the stock radius arm brackets your set. but if you have a stage 1 lift you probably have drop brackets so those will not work. go to any wrecking yard and get both stock rad brackets and your set. not sure why this is so confusing
ChaseTruck754
Ford Truck Parts for Sale
Oct 18, 2013 08:37 PM
keiths78f150
Sep 9, 2012 09:10 PM
SneakyF350
Apr 4, 2008 11:45 PM
midcal48
Jan 7, 2008 08:13 PM
SoCalSuperCrew
Jan 13, 2007 02:38 PM
