Intermittent miss
Old Dec 22, 2003 | 09:36 PM
stevorino's Avatar
stevorino
Intermittent miss
I recently tuned up my truck - new wires, plugs, filter, oil- and I get an occassional miss. I only notice it at idle, and not at any particular time. Today I started it and it idled rough so I turned it off and resarted it and it ran fine. Other times I will notice the rough idle after driving it for a while and if I turn it off and restart it the miss goes away. Any ideas?
Old Dec 23, 2003 | 09:24 AM
jwtaylor's Avatar
jwtaylor
get a haynes and check your codes, or go to autozone and they will pull your codes for free, get them and come back here and post, someone will tell you what direction you should take or give you a link to a site that lists the codes and possible problems. Did it only occur after your tune up? If so, I would double check the plugs wires, as in, are they on the right cylinder? Probably are, but it never hurts to double check.
firing order 1-5-4-2-6-3-7-8
they run counter clockwise on the cap
passenger side of block front to back is 1-2-3-4
driver side of block front to back is 5-6-7-8
Might consider changing the cap and rotor, as well.
Good luck and I hope its something simple
Old Dec 23, 2003 | 09:30 AM
luckild's Avatar
luckild
Check timing chain, sounds like it is sloppy and ECM is making lots of adjustments. Good luck.
Old Dec 23, 2003 | 12:11 PM
dbuck50's Avatar
dbuck50
Possible timing chain stretch...how many miles?
I would make sure to replace the fuel filter to make sure you are getting enough fuel at idle. Also many have reported having plugged injectors due to rust in tanks/system/fuel rail. Pulling your injectors/fuel rail and having them cleaned and flow tested could nail that down.
Old Dec 23, 2003 | 05:35 PM
stevorino's Avatar
stevorino
I've pulled the codes and I get 11 accross the board and I've double checked my wires and plugs. The fuel system seems like a more likely problem.
Old Dec 23, 2003 | 05:44 PM
stevorino's Avatar
stevorino
I also changed the cap and rotor when I did the wires. This engine has about 70k miles on it.
tracyclifton
May 28, 2014 02:29 PM
theseeker
Apr 24, 2014 10:29 AM
jimandjimmer
Sep 12, 2009 07:23 AM
Robvan
401, 477, & 534 SD Engines
Jun 10, 2008 10:25 AM
jemini
17
Sep 30, 2007 06:23 AM
