1978 - 1996 Big Bronco
Engine cutting off
Old Sep 21, 2004 | 01:43 PM
Semperfi45601's Avatar
Semperfi45601
Engine cutting off
I have a big problem. My Bronco is really giving me fits lately. Its such a weird problem I almost don't know how to describe it, but here goes;
When I start her up, she is fine. After about 5 min she will spit and sputter, BAD! If I come to a stop, it dies. I put it in neutral and start it and it will idle perfectly but once I put it into gear, it dies. It takes a while for me to get it going to where it won't die. If I am on the highway and it does it, the engine just loses all power and goes to an idle no matter how far down the gas pedal is but if I put it in neutral I can gun it a few times and put it back in gear she will go ok for a few sec before it does it again. Now the funny part, once it warms up after about 15 min or so, it runs great. If I start it and let her run for 15 to 20 min in park and then get in and go, it is great, not a problem in the world.
If anyone has any idea what in the world my rig is doing, please help me out. It is driving me nuts, esp when it dies in the middle of the city street full of traffic.
Thanks to all for the help...
90 302 5.0L
Old Sep 21, 2004 | 04:54 PM
Kemicalburns's Avatar
Kemicalburns
pull the codes and see what the ecu says. it can be done with a paperclip if you go here and read www.fordfuelinjection.com. also when was the last time it had a tune up, with new plugs, wires, cap and rotor. timing could be off to. fuel filter could be clogged . you may also have a clogged catylitic converter it will cause loss of power to . check these things and get back to us
late
Old Sep 21, 2004 | 09:37 PM
Jdenninger's Avatar
Jdenninger
could also be the TPI on the side of the dizzy. Have you checked the tranny fluid level?
Old Sep 21, 2004 | 10:06 PM
Semperfi45601
late
I tried to pull the codes and nothing. I just tuned it up about 1 month ago. It has new plugs, wires, cap and rotor and timing was checked. Fuel filter is brand new. Just put it on last weekend when I changed the tank.
Old Sep 21, 2004 | 10:08 PM
Semperfi45601
Tranny fluid is fine. In fact, all fluids are perfect. That is one of the first things I checked. I don't mean to sound stupid but what does TPI stand for? I am learning as I go. I know some basics but still have A LOT to learn.
Old Sep 21, 2004 | 10:25 PM
Jdenninger's Avatar
Jdenninger
the TPI is the gray module on the side of the dizzy. when it overheatrs too much they fry. is controls the dizzy.
Old Sep 22, 2004 | 12:40 AM
greystreak92's Avatar
greystreak92
Um, its TFI and it is the abbreviation for Thick Film Integrated circuit module. They are notorious for dying especially on models that still have them mounted to the distributor. If you can't get any codes from the PCM (Powertrain Control Module) though, you are going to be on a wild goose chase. Honestly it sounds like a compound problem. MAP (Manifold Absolute Pressure) sensor and IAC (Idle Air Control) solenoid perhaps but without codes you could guess as well as anyone.
Old Sep 23, 2004 | 07:06 AM
fcarruth's Avatar
fcarruth
On my 89, the TFI module seems to be the culprit every 2 or so years. Make sure that plug wires #7 & #8 are not crossing each other since that is proven bt Ford to cause problems and has hel[ped quiet a few on this forum. IF you replace your TFI for less than $30., you will need a special tool to take the screw out and you will also have to loosen the distributor so make sure you mark it 1st or have a timing light ready. If you do retime it, make sure to take the spout off. Get a Haynes manual and it will walk you through all of these procedures.
Good luck,
Old Sep 23, 2004 | 08:05 AM
Semperfi45601
Good luck,
Thanks for all the info. I think I will try changing the TFI module. It is a start and it isn't to much $$. Anyone have any pics of this thing so I know what I am looking for??
Old Sep 23, 2004 | 10:02 AM
djjoshuad's Avatar
djjoshuad
haynes or chilton manual should
Old Sep 23, 2004 | 12:23 PM
fcarruth's Avatar
fcarruth
If you're standing in front of your engine and looking at your distributor, it is on the right hand side and is grey in color. It is about 1/2" thick X 1 1/5" tall X about 4" wide.
Good luck,
Old Sep 23, 2004 | 04:20 PM
The Tree's Avatar
The Tree
I had a problem that was similar except the engine just died. I had a loose connection going to the distributor and then had to replace the control module(brain box). Although I have a 78 probably not as complex.
Old Sep 23, 2004 | 07:35 PM
skelator's Avatar
skelator
you completely described a problem i had before, change the fuel filter, check all of your idle adjustments on the carb and pour a can of chemtool into the gas tank. your main problem is the carb.
Old Sep 23, 2004 | 07:47 PM
skelator's Avatar
skelator
i pulled the brain box and took it up to the ford house and they wanted 80 to test it. they told me it had to be in the truck. i asked the guy, "if i could drive the truck up here do you think i would need to test this damn thing?" so i called vatozone and they told me 100 dollars for a new one. so whats a better idea? spend 180 to test it, find out that its crap and then replace it? or just buy a new one cause the damn thing is 20 years old to begin with?
Old Sep 24, 2004 | 08:53 AM
Kemicalburns
the brain box is not the tfi module. the tfi module should not be $100 either. do you have a digi cam if so snap a pic an show us what your holding
