Whats the cause???
Old Dec 18, 2011 | 03:57 PM
74F2504by4's Avatar
74F2504by4
Question Whats the cause???
Need help figuring out why the front driver's side tire leans in at the top. From the front of the truck, the tire looks like a "\". I have replaced the tie rod ends, I had to replace the hydraulic assist control vlave anyways. But still the tire leans. Not sure what to try next. I need to fix this so I can drive the truck without killing tires. Any help would be greatly appreciated. It is a '74 F250 4x4 Ranger. I have pictures but they are too big to upload here. Let me know if you would like them I can email them.
Thank you
I was able to get some pics uploaded:
https://www.ford-trucks.com/forums/m...tire+lean.html
Old Dec 18, 2011 | 04:29 PM
tbear853's Avatar
tbear853
Definately ball joints or king pins & bushings, I think your '74 F250 will have the king pins.
Dana 44 Solid Front Axle: Reverse Spiral and Standard Housing info..*
Dana 60 Solid Front Axle: Reverse Spiral and Standard Housing info..*
Old Dec 18, 2011 | 04:47 PM
montana_highboy's Avatar
montana_highboy
X2, looks like the king pins and/or trunnion bearings are shot on that side, if so, you'd have some serious death wobble action going on, have you jacked it up and gave the tire a good rocking back and forth to check for slop?
Old Dec 18, 2011 | 04:56 PM
74F2504by4's Avatar
74F2504by4
Thumbs up
It does have slop. How difficult is it to do the kingpins? If I had to take into a shop what am I looking at for cost of repair?
Thank you for the diagnosis help and info.
Old Dec 18, 2011 | 05:18 PM
montana_highboy
First i'd ask yourself if you really want to invest the time/money to rebuild your low pinion, closed knuckle, drum brake axle, OR, pick up a 78/79 high pinion, open knuckle, disc brake axle that's virtually a direct bolt-in.
Old Dec 18, 2011 | 05:41 PM
74F2504by4's Avatar
74F2504by4
Well, I really do not want to modify the vehicle far from stock. So I am willing to rebuild this one if possible.
Old Dec 18, 2011 | 05:53 PM
montana_highboy
It's certainly a job you can tackle yourself if you're mechanically inclined, or if you want to save money on labor costs..... i'd highly recommend you have the factory truck shop manual on hand when/if you decide to tear into it, it's been awhile since i've been through one of these older axles, NAPA may still have access to most of the parts you need, if not, these guys here should have most everything you need.... QUAD 4x4 Home Page
BioBuner
Mar 7, 2011 05:59 AM
dmeyer 351 4x4 rebel
Dec 20, 2010 10:39 AM
WorkhorseF250
Jul 3, 2010 07:56 PM
mastermitch
Mar 12, 2007 11:13 PM
Screamin T/A
May 7, 2004 04:07 PM
