cargo light template
Old Dec 16, 2011 | 10:53 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I'm going to install a factory cargo light on the Pumpkin and have been trying to find a good diagram of the factory opening.
Grinnergetter and RunninD tried to help (thanks, guys).
What I ended up doing was using the gasket to make a template.
I figured I'd post it here so anyone that might be thinking about puting a cargo light on their "baby" will have it.
One thing thats real important. The hole IS NOT centered on the cab! The hole is slightly offset to the passenger side. When laying out the dimensions, use the vertical centerline between the two mounting screws as the overall vertical centerline.
Old Dec 16, 2011 | 04:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic: Section 137, page 2.
The cargo lamp lens and its gasket are the same as the 1967/72 cargo lamp and are also the same as 1964/65 Thunderbird backup lamps.
The entire Thunderbird backup light assy was used as a cargo lamp on 1967/72's.
Old Dec 16, 2011 | 04:40 PM
WyoFlyFisher's Avatar
WyoFlyFisher
Nice idea, might have to consider doing that to the '79!
Old Dec 16, 2011 | 05:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Bill, that explains why the Ford logo is upside down, I was wondering about that.
Old Dec 16, 2011 | 05:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you use the correct one for a '79 the drawing won't work. In mid-77 the design of the cargo lamp was changed.
However there's no reason why you can't use a pre mid-77 light. The roof is the same, just the light changed.
Old Dec 16, 2011 | 06:28 PM
musicmanbiker's Avatar
musicmanbiker
Is there a reason the light isn't centered? Or is it the light itself? John
Old Dec 16, 2011 | 06:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The light itself IS centered. It's the opening that's cut into the roof that isn't centered.
On the back side of the light the wiring and the bump out on the casting is off center. This is something that's not visible from the front but it means the opening has to be off center. If you cut the hole centered in the middle of the roof, when you mount the light it will be off center to the drivers side by about 1/2".
Old Dec 17, 2011 | 04:10 PM
NorthwestX360's Avatar
NorthwestX360
Template copied and filed away for future use; thank you. Question: how high above the rear window weatherstripping is the bottom of the hole? My F350 is a Lariat that is loaded with most options, but this one is missing. I would have thought the cargo light would be part of the Lariat package. My previous truck was a Custom, and it had one. Actually, I used to think the cargo light was a standard feature on all trucks.
Even though my truck is "on the back burner" nowadays and I only drive it once a month to exercise it, I check this website everyday for tips and info. I'm mulling around a Cummins swap. I have a '97 Dodge/Cummins, so I'm familiar with them. But that project will have to wait. The first priority is to build a new house!
Anyway, thanks MikeoOoOo and Number Dummy and all of you for all the great info.
Andy
Old Dec 17, 2011 | 05:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks NorthwestX360, I'm not sure of the vertical location of the light. I'm going to research it some but if I can't come up with anything I'm just going to position it so it "looks right" to me.
Old Dec 18, 2011 | 01:28 PM
RunninD's Avatar
RunninD
Mike,
My local JY just got in a 2wd with a light, so I'll get you the vertical measurement on Monday.
Also if anyone is interested there's a pretty nice 2wd F100 in Wyoming and knowing the yard owner he's got the title due to where its sitting! I'll pass on more after I fondle her on monday!
Old Dec 18, 2011 | 02:04 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Just took a quick measurement on dad's truck. Between the light housing and weatherstrip was a 3/8" gap. 74 XLT with factory cargo light.
Old Dec 18, 2011 | 02:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Rouge-Wulff. From the pics I've been able to find it did look pretty narrow, your measurements confirms it.
Tried to rep you but it said I had to spread it around first.
Thanks again.
Old Dec 18, 2011 | 03:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by RunninD
Mike,
Thanks RunninD, Same deal as with Rouge-Wulff, Tried to rep you but it said I gotta spread it around.
Old Dec 18, 2011 | 04:47 PM
Rogue_Wulff
Tis ok mike, I repped you in return anyways, prolly owed it you.
Old Dec 18, 2011 | 06:03 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Rouge-Wulff, your reps got me my fourth "greenie".
Marc (Turbohunter) rep'd you for me, thanks again Marc.
Mike
SCRebel
Nov 2, 2018 02:10 AM
Rusty_S
Aug 26, 2015 08:51 PM
jmikeyj4
Nov 29, 2010 11:21 AM
1972-34ton
Aug 3, 2009 08:41 PM
custom_nirvana
Mar 9, 2009 09:35 AM
