GPCM Test
Old Dec 18, 2011 | 07:16 AM
tom135's Avatar
tom135
GPCM Test
Hi all,
I was wondering if there is a way to test the GPCM to make sure it is working properly. I'm having clod starting problems, I'm changing my glow plugs and glow plug harnesses on spec.
Thanks for any help
Old Dec 18, 2011 | 08:05 AM
bismic's Avatar
bismic
Install an inductive ammeter on one bank at one of the two harnesses at the Glow Plug Controller Module (GPCM). You can get up to 200 A at first, but then should stabilize around 35-45 A. Check the other bank with the inductive ammeter. Both sides should read the same. If not, check the amps to each individual glow plug to determine which one (or ones) is bad. Each glow plug should draw 10-12 Amps.
Old Dec 18, 2011 | 09:59 AM
cheezit's Avatar
cheezit
why not just ohm out the glowplugs. lots of other reasons they dont start when cold. 6.0 is not know to fail glowplugs that often
Old Dec 18, 2011 | 11:01 AM
Sader's Avatar
Sader
As bismic stated it is easiest with an inductive ammeter. I just had to replace the plugs and harnesses in my 05 recently, 4 of them tested bad they only had 77k on them. Ohming the glow plugs is the best way to identify if the plugs are good as cheezit says.
My FICM also tested bad and that was the remaining part of my cold start issue.
Both are fixed and she starts like new!
Old Dec 18, 2011 | 02:08 PM
tom135's Avatar
tom135
Thanks for the info. I will check the GPCM with an inductive ammeter.
I'm in the wheel well now and have replaced the glow plugs and in the process of installing a new harness. I was wondering if there is a trick to seating the terminal ends into their respective holes. I'm having a hard time pushing them in.
Thanks for any help.
Old Dec 18, 2011 | 03:30 PM
tom135's Avatar
tom135
Well it's done, I ended up using a long flat tip screwdriver and gently tapped them in from inside the wheel well.
Beer time
Old Dec 18, 2011 | 03:53 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE Tom... I see you already have help your way.
Old Dec 19, 2011 | 04:55 AM
tom135's Avatar
tom135
Thanks, The help is always appreciated. without this site my truck would surely be in the scrap yard.
the_auto_tech
Aug 21, 2013 08:45 AM
RougeDoc
Mar 11, 2009 12:16 AM
jongirouard
15
Oct 23, 2007 01:13 AM
pabs
Dec 18, 2006 08:31 PM
Ed the outdoorman
Jul 9, 2003 10:17 PM
