Cold weather starting
Old Dec 16, 2011 | 05:35 AM
thinksnow's Avatar
thinksnow
My 06 had always started very easily in the cold weather. The past 2 weeks I've had to crank it over quite a while before it would start, and it hasn't been really cold yet. It's cranking strong so I don't think the batteries are weak, they are the original batteries as the truck only has 38k on it. Any ideas? I was going to fill it up with some fresh diesel this evening.
Old Dec 16, 2011 | 05:49 AM
npccpartsman's Avatar
npccpartsman
The batteries and charging system are the first place I'd start to check. It can seem to crank strong but you might not notice that it gets infinitesimally slower and slower over time. Also check the FICM voltage (tech folder for procedure) just for a baseline. Mileage has nothing to do with batteries and yours are 5 years old now.
Old Dec 17, 2011 | 10:11 AM
thinksnow's Avatar
thinksnow
Well I put to new batteries in this morning and it still crank over for a while before starting. I guess I'll have to look at the FICM next.
Old Dec 31, 2011 | 04:03 PM
thinksnow's Avatar
thinksnow
Ok, I replaced both batteries and that didn't seem to solve the problem. I checked the voltage on the FICM and the lowest it read was 48.2 so that leaves me a bit more confused. Its supposed to get very cold on Tuesday, I will see how easily it starts then. I straight piped my truck this summer (CAT still intact). Would that effect cold weather starts?
Old Dec 31, 2011 | 04:42 PM
nanuke1's Avatar
nanuke1
I have the same issues with my 05. At first I suspected the fuel filter which was from Napa so I replaced with MotorCraft - no change. I have new glow plugs and have had the Dealer check all injectors etc.. All is well except the slow starting, it fires but takes a long time to get it running even at 30 degrees. I keep hearing about the fuel pump and probably should check that next. Good luck - its frustrating knowing its going to get very cold next week. I'll have to keep it plugged in.
F33lmywrath
Sep 18, 2016 09:42 AM
Restlesswildman
Dec 8, 2013 11:13 PM
Fifty4F100
20
Jan 12, 2010 08:28 AM
RussellF
Jan 16, 2009 10:26 AM
hd4ever
Dec 5, 2008 07:15 AM
