Ford specific ODBII tool?
Hello everyone, I just purchased a 2000 Navigator and my backup sensor system is not working. According to the online info I should be able to scan it and tell which pieces of the system is malfunctioning based on the codes. However, this requires an ODBII scan tool that's capable of accessing Ford specific modules, such as the backup system, not just the engine as is the case with most cheapo scan tools. Any recommendations for the right tool for the job?
Thanks,
Tomasz
Thanks,
Tomasz
Their scanners will be worthless for the auxiliary systems. Those systems communicate over the OBDII link (SCP bus, actually), but are not part of the OBDII system.
You need a much more advanced scan tool. The scanners used in professional shops (Snap On or MAC, for example) certainly will work. There may be less expensive alternatives available.
Here is a complete Ford Module list. Ford Module List
I have AE and have used it on 3 different Fords. It has been extremely beneficial and was not very expensive.
ChRoNo16
05-30-2016 08:17 PM
Big_Man_Brad
03-04-2008 06:17 PM
